Tap Tempo Osccilator
Started by lh_satch, September 28, 2005, 01:18:08 PM
lh_satch
Hi
I am currently studying my final year at Uni and for my end of year project I would like to make a tap tempo osccilator (tremolo) unit.  Could anyone tell the best place to find a schematic for a tap tempo project.
Martin
aron
Most of these I have seen have been digital. Is there an analog tap tempo in a pedal?
gez
Quote from: aron on September 28, 2005, 01:19:31 PM
The only thing I know of in the analogue world that's remotely close is synching of the LFO to the initial attack of a note/chord/accidental bang of headstock on speaker cabinet.  Other than that I think you're going to have to go digital...
I did just come up with an implementable analog tap tempo oscillator. Mostly analog, anyway.
You use a digital controller to measure the tap time, then put out the right LFO frequency from the controller. That's the digital part.
The analog part is to phase lock the analog oscillator to the digital output. I think that a single CD4046 would do the trick. Capture time is going to be a problem, so the design of the loop is going to be important.
nikStomp
Hello R.G.
I'm really interessed in your circuits can you post a schematic?
Nicola
ps do you think that this http://www.tomwiltshire.co.uk/sdiy/envgen.html
can work in a tremolo circuit for synth like sounds?
gez
IIR, there's a PIC project in the digital forum: well, the code at any rate.
I haven't built one yet, only figured out how to do it. There's a lot of digging to be done between here and there.
One thing about programmable controllers is that the schematic is almost useless. There is a power supply in, maybe some switches and pots that connect directly to pins on the controller, and then outputs from other pins. The controller becomes all there is, and you can't tell from the schematic what the insides do. It becomes A Simple Matter of Programming - which most people will tell you isn't all that simple.
I read once that computers have a way of hollowing out whatever they get into. Eventually, there is the computer, and all inputs and outputs go directly into and out of it. Everything else is 'eaten up' by the computer chip.
Quoteps do you think that this http://www.tomwiltshire.co.uk/sdiy/envgen.html can work in a tremolo circuit for synth like sounds?
Yes.
Even more interesting is the VCLFO at the same site. It could easily be made into the replacement for the PLL, or the entire tap tempo chip. However, it's A Simple Matter Of Programming, and in this case, someone else's programming.
