True Bypass a Boss TU-2
Started by John Egerton, September 29, 2005, 05:25:02 PM
John Egerton
Hey guys...
I've true bypassed all of my Boss pedals except for one... My TU-2 tuner pedal...
I'e tried for ages to find the correct transistors to pull...
There are multiple ones of the same values scattered across the board...
I started by pulling the ones in the same position as in all my other pedals to no avail...
I've also randomly pulled some to see if this works...
The pedal when powered on just comes on for a second, then goes to bypass as it does when it is stock...
Does anyone know the precice location of the transistors to pull on this board?
Thanks guys
John
Save a cow... Eat a Vegetarian.........
jaman
I have the same problem...
Can anybody help ?
i would be grateful !
Ben N
Why? the bypassed TU2 makes a good buffer for your pedalboard, IMO.
jaman
I would like to take out all the board and put in a box with other pedals.
That's why I want to make it true-bypass
thanks !
Making it true bypass is easy, you just take the input and output wires and connect them to your switch using your favourite true bypass wiring.
I guess what you really want to know is how to make it so the tuner is always on?
jaman
Quote from: slacker on October 31, 2008, 02:06:17 PM
Exactly !  ;)
I'll see if I can figure it out.
jaman
