Multi Space Filter
Started by StephenGiles, October 05, 2005, 04:44:36 PM
liquids
As much as I'd like to, I'm too much of a newbie to understand all that...but I'll get around to it eventually...once I understand all of this more and have my workspace back, for starts.   :-[
Breadboard it!
StephenGiles
StephenGiles
#22
http://www.4shared.com/file/89784300/b7d68e64/Space_Filter_S__H.html
This is easier to read now, I may have a go at this over the weekend.
StephenGiles
 :icon_idea: But will the sweep generator stay low after the end of each sweep or will it need some more circuitry to nudge it low?
StephenGiles
Come on, lets see some spark!
MarcoMike
How is that sample&hold supposed to work?I'm scratching my head here... ???
as far as I understand.... the envelope generator (is it that?) triggers the 2n3819... which opens and let the cap be charged...
but after that U2 is fed with the voltage stored in the cap... so U2 delivers a constant voltage which depends on your pick.... then?  ::)
Only those who attempt the absurd will achieve the impossible.
StephenGiles
#26
At this stage these are just ideas for discussion.
StephenGiles
#27
Some further explanation of this circuit idea:
With the system at rest, no current flows through the 10k resistor from IC1b output into IC2  pin 1. This results in the transconductance amplifier portion of IC2  being effectively disconnected from it's darlington emitter follower output stage, hence the voltage at IC2 pin 7 follows pin 3, which is at the voltage set by the Stop Frequency control, buffered by IC1c.
When a note is played, IC2 is energised by the current into it's pin 1 and becomes a voltage follower, forcing pin 8 to equal the pin 3 voltage, set by the Start Frequency control (see below). The pin 1 current soon ceases to flow, however, and the voltage at pin 7 decays through the RC network to the Stop Frequency voltage at a rate set by the Sweep Rate contol.
Now, we want the Start Frequency control to set a voltage proportional to the strength of the note played, in other words an Adaptive Start Frequency. The basic Space Drum sweep generator used in the circuit has a fixed Start Frequency however, which is determined by the setting of the control pot.
A possible way of achieving this is to pass part of the voltage output of buffer/amplifier IC1b to the pulse generator consisting of U2, U3 (1/2 13600??) and associated components. (I am a little mystified about R9 hanging from U3!!) The output of IC1b is also passed to FET Q1. With the system at rest, Q1 is off. A pulse generated each time a note is played will momentarily turn on Q1, allowing the instantaneous peak voltage voltage taken from IC1b to be sampled by the other half of U2 and put on the tag of the Start Frequency control which was formerly connected to the positive supply.
So each note played both energises the sweep generator and controls it's Start Frequency according to the strength of the note. The resulting voltage can be used to control a suitable VCF, so once again, we get a Start Frequency following the strength of the note played, but a Sweep determined by a separately controlled CR network.
StephenGiles
Now then, we're off to see 'Slum Dog Millionaire'. When we get back...........I want answers :icon_biggrin:
Quote from: StephenGiles on February 28, 2009, 10:15:51 AM
Sorry - can't help, I just build variations on FF's.
StephenGiles
puretube
There are two "U2"-s in the schemo (circuit diagramme...)  :icon_question:  [2 youtoose  :icon_lol:]
FF = Fuzz-Face...
chicago_mike
Shouldnt datasheets for the LM13600 / LM13700 and CA3280 have some of these ideas, or even a cmos cookbook?
I have datasheets of the 3280 I think,, its just a more expensive 13700 with a different pinout I think.. :icon_confused:
StephenGiles
Quote from: puretube on February 28, 2009, 01:29:03 PM
FF = Fuzz-Face...
Updated re U2!
A possible way of achieving this is to pass part of the voltage output of buffer/amplifier IC1b to the pulse generator consisting of U2b, U3a (1/2 13600??) and associated components. (I am a little mystified about R9 hanging from U3!!) The output of IC1b is also passed to FET Q1. With the system at rest, Q1 is off. A pulse generated each time a note is played will momentarily turn on Q1, allowing the instantaneous peak voltage voltage taken from IC1b to be sampled by the other half of U2 and put on the tag of the Start Frequency control which was formerly connected to the positive supply.
Quote from: chicago_mike on February 28, 2009, 03:15:35 PM
No chance, the sweep generator using a CA3094 was from a clever EH designer I knew in 1980!!
StephenGiles
StephenGiles
#36
Think about it, the sweep generator will only be energised when the voltage at IC1b exceeds the level set by the Sensitivity control - rather like the Microsynth, which  will always sweep up (or down) to the same point set by the start frequency control however, but my circuit will provide an adaptive sweep initially according to the strength of the note played.
So perhaps Adaptive Space Filter might be a better name. :icon_biggrin:
StephenGiles
Show me another Adaptive Autofilter if you can. ???
orangetones
Are you still just doing this all in theory? or have you breadboarded any of this?
I am always interested in these funky filters...
StephenGiles
Quote from: orangetones on March 02, 2009, 02:31:10 PM
The sweep generator was breadboarded many years ago having converted the Space Drum circuit from a CA3094. The rest is all in theory for which I have this evening sorted out some of the parts. It will be on breadboard before too long, but judging by the overwhelming enthusiasm I have seen - perhaps fear even that it won't fuzz for this I am not too hopeful that it will find it's way to anyone else's breadboard!!
