MAX660, charge pump, 100mA max current.
Started by nelson, October 08, 2005, 07:08:15 PM
nelson
I have seen ALOT of threads asking about charge pumps.
Never heard this chip suggested. It has a higher current handling capability.
Better suited for say the Maestro F/S+H, or other current hungry circuits demanding higher voltages.
It also has the benefit of selectable frequency from 10khz to 80Khz,  like the MAX1044.
http://cache.national.com/ds/MA/MAX660.pdf
Is there a reason this chip hasnt been suggested before?
Woops, looking at the datasheet it has a max supply voltage of 5.5v..... :icon_cry: :icon_redface:
My project site
Winner of Mar 2009 FX-X
PharaohAmps
I've used this chip with a 9V supply before - once in an MXR Flanger whose transformer failed, and a few other things.  The MAX1044 works great for low current circuits, like my Magnolia overdrive pedal, but for anything more than 1 or 2 op-amps, I like the MAX660.
I'll email my guy over at Maxim / Dallas and ask about the input supply voltage.  Maybe they CAN take 9V...
Matt Farrow
Pharaoh Amplifiers
http://www.pharaohamps.com
markusw
nelson
http://focus.ti.com/lit/ds/symlink/lt1054.pdf
Yep, looks like a great charge pump, needs an additional cap from cap+ to OSC in order to increase oscilator frequency out of audio range. Is cheaper, has higher current handling and a regulated output!
Will def be using this chip!
Thanks Markusw
My project site
Paul Perry (Frostwave)
Another vote for LT1054!
By the way, jim williams at linear technology recenty said that these days, analog design skills are so rare, that instead of answering questions about LT chips, he's having to actually design the boards for customers. Don't all ask him at once, though, I think you only get him to design stuff if you are buying at least 50K + of chips. :icon_wink:
nelson
My project site
bluesdevil
Quote from: nelson on October 08, 2005, 08:41:35 PM
Thanks Markusw
Nelson, if possible what exactly would I need to do to  use the LT1054 in this circuit:
http://aronnelson.com/gallery/TheBigMan-Layouts/voltagedoubler
I would like to use it for the 18v  PT-80 build . Thanks .
"I like the box caps because when I'm done populating the board it looks like a little city....and I'm the Mayor!" - armdnrdy
nelson
Wouldnt bother with that layout. Design a new one based on this schematic.
My project site
bluesdevil
