Nurse Quacky "Quacks" but the decay .... !!
Started by MartyMart, October 15, 2005, 01:09:53 PM
MartyMart
Finished this off during the last few days, using Torchy's layout and the schem
from www.home-wrecker.com
He had all the pots lugs 3&1's reversed, so I'm glad I had the schem around also !
I only changed 1 part, 47ohm for the 51ohm that I didn't have.
OK, it all works fine and after some "fiddling" with knobs ( technical term for adjusting! )
I got a setting which almost works, sensitivity/attack and range in perfect harmony......
But .... I have a nasty "ripple" happening most of the time, even on long single chord
strokes   !
I've searched and read a few other comments/suggestions, but there doesn't seem to
be a "fix" that I can see ?
I've used the 22uf cap, would a 22+10uf help for this kind of "loooong" filter type chord use?
If so, is it better to use a switch to add that in, or even go with a 47uf  ?
Thanks to Torchy for the layout which works a treat :D
Marty.
MartyMart
Bump !
Anyone have suggestions for "smoothing" this out a bit ?
Could an LDR help ?
M.
B Tremblay
That ripple is one of the shortcomings of the Dr. Q and its derivatives.  A larger cap may reduce ripple, but the decay will also be increased.  Try a 47u and see how that helps.
Also, you could try adding a 100n cap to ground between the LED and 51 ohm (47 in your build) resistor.  That may smooth things out a little.  I haven't tried that, but it could work.
B Tremblay
runoffgroove.com
MartyMart
Thank's for that, I'll certainly give it a try !
Marty.
Vsat
Marty,
Is the amount of ripple reduced very much if you play just a single sustained note (even a loud sustained note)?
Becomes more obvious when more than one note is played at once, particularly lower notes?
Mike
MartyMart
Quote from: Vsat on October 16, 2005, 08:09:47 PM
Marty,
Mike
Yes, there's almost no ripple on single notes and 5ths, but
anything more and its "wobbling" all over the place as it decays !
M.
MartyMart
Well perhaps I've been mis-reading some of the posts on the Quacky ?
This version with a TL072cn was thought to be a "fixed" version, but I've
just been trying both LM358 and LM1458 with much better results !!
all three controls are more responsive, perhaps the range of the sweep is
a little more controlled, but its a definate improvement, with more variation
available :D
I'll still try the small mods suggested, but its now much better, perhaps I'll
stick with the 1458 ...... Mark ?
Marty.
spudulike
MartyMart - check this out. The chip AND the tranny are important to the overall sound of the pedal.
http://www.diystompboxes.com/smfforum/index.php?topic=35760.msg251999#msg251999
MartyMart
#8
Quote from: spudulike on October 17, 2005, 05:56:06 AM
Great, thanks for this, which never came up in any search BTW !!
I'm happy with LM1458/2N5088 at the moment  :D
seems to be a good "pairing"
EDIT: The suggested 100n cap to ground from the junction of the LED/51r is worth doing,
whilst it didn't solve things totally, the decay seems smoother and the "ripple" is slower and
also smoother sounding :D
Marty.
In general, the degree of satisfaction people get from their envelope-controlled wahs is a function of their playing style.  If the notes come and go quickly, it's a bit like never noticing how truly bad the dessert is if you fill up on the bread and salad that precedes the steak.  Admittedly, a great deal of what drives interest in such autowahs are fabulous bass-slapping sounds heard on record or in concert, which tend not to allow notes to linger.  My own experience is that a great many autowah designs just don't sound that wonderful during the second half of the decay phase because the envelope followers tend to be bare-bones, or because the time constants are fixed in a manner that anticipates the note/chord being swept aside (pardon the pun) very quickly in lieu of the next note.
One thing to try is a larger cap or capacitance value, with a decay pot in parallel.  So, a 33uf cap in tandem with a 500k trimpot.  The idea is that somewhere in there is an optimal decay time that will smooth out the ripple enough without being too sluggish from a playing perspective.  Note that a 33uf capacitance will also slow down your attack time, (so 47R for attack/charge-up/current-limiting resistor is a good choice).
The 1458 is not exactly a gift from the audio gods, but it works well enough in this instance.  Jack Orman's biasing change that came in via the Dr. Quack should have made op-amp choice one driven purely by noise and current draw concerns, rather than sweep width concerns, however if a 1458 works for you, I say stick with it.
  Ross comp in front...changes the way the EF works, might be worth messing around with, will certainly 'even things out' as far as peaky voltage swings hitting the input, may help out the decay steadiness...may be too much also...something to think about thinking about, anyway...lol.
  NQ Sounded great when set up just so' for me, but change anything before it like guitar volume and it's needing reset up for max Quax.
Vsat
Breadboarded an envelope follower on the weekend, fairly generic design. Checked out it's operation with the dual-trace scope.
Upper trace displayed the audio signal which was fed in, lower trace displayed the output from the averaging filter of the follower.
With strictly monophonic inputs, it works well... does a good job of replicating the envelope of the input signal. Play two or more notes simultaneously, and things are not so nice.... especially noticeable on sustained notes.
As a test, fed in these two signals - a steady 80 Hz sine plus a steady 85 Hz sine, equal peak-peak levels. Fed in individually, each produces a steady DC output is produced with very little ripple. Feed in both, and you get  a huge  amount of ripple at 5 Hz... the two signals are beating with each other. Looking at the input signal with the scope, the beating is clearly visible (no surprise there), it looks like a string of pearls, and the envelope follower is doing a wonderful job of replicating the beat envelope.  Although the follower time constant is set up to filter out ripple at the expected range of frequencies produced by an instrument, it is not able to filter out the ripple from a polyphonic signal with all the low-freq beating taking place... unless a very long time constant is used, which will make the decay very sluggish.
This is probably the reason why some people report that full-wave rectification does not yield much better results than half-wave...the major source of ripple with these followers is low-freq beating between notes that are close together, ie. chords. Use it to control a filter and it sounds like the filter is modulated by an LFO.....an interesting problem.
Cheers, Mike
Useful observation there, Mr Pike.  ;)
One of my guitars has a home-made fret job, and with the frets so tall (and its owner so damn cheap :icon_rolleyes: ), there is often wearing or other deformations of the strings at the most commonly-used frets.  The sort of thing that when you pluck the string, you can see little red and blue bands resulting from the beats within a string.
I'm wondering if there is some virtue to highpass filtering a rectified signal, to remove any sub-audio components, or will that have much less impact than expected for the likely parts count?
Vsat
How would the highpass scheme be implemented? Would there not be a risk of filtering out the slow-changing parts of the envelope  along with the beating-ripple? The idea is to defy the laws of nature... the env flwr is doing it's job... just that this nuisance phenomena called beating takes place. Perhaps use a harmonizer to shift up 3 octaves so 5 Hz beat becomes 40 Hz and is more easily filtered? (without harmonizing the audio fed into the wah circuit).
Mike
StephenGiles
#14
Which brings us back nicely to my Space Filter envelope generator
http://www.diystompboxes.com/smfforum/index.php?topic=36221.msg255718#msg255718
Mike, I'd be interested to hear what you see on your scope with this one because the start frequency = strength of note played, then decays at sweep rate time and not per input.If matched to the right VCF I think this would sound good.
Stephen
Quote from: Vsat on October 17, 2005, 02:29:20 PM
Mike
Or do what Harry did - use a hex pickup and 6 envelope followers!  :)
StephenGiles
But didn't he use an element of fundamental extraction too, if I understood correctly what he recently posted here?
Stephen
MartyMart
I seem to remember this circuit not woking at all well in a thinned out "guitar" mode ...
It was left in full range Bass mode, to work well .....
Love tones filter pedal ( name escapes me "filteratron/wobulater thingy" ) sounds great ... but then it should for
600 bucks !
Marty.
Vsat
Steve,
Could you please post the original Space Drum schematic to the list....(again).
Mine did not print out right, looks like it's sliced into 4 sections which are jumbled about in an unreadable manner.
I think I see what the env-sweep circuit in your drawing is trying to do, however it won't do it properly. The 13600 Iabc pin is always about two diode drops above the V(-) line (as it should be, since it is a current mirror input referenced to negative rail), but in the drawing it always has a current going through it, since the op amp which drives it has an output which sits at ground in the quiescent state. The Iabc pin is being used as a half-wave rectifier, and this pin should be deprived of current for alternate half-cycles to work properly. There should probably either be a Zener diode in series with the Iabc pin, or the pin coupled to the op amp output through an electrolytic capacitor with a reverse clamping diode between the Iabc pin and V(-).
Probably still behaves the same way wrt beating input signals.
Mike
A.S.P.
how about massively lowpassing the control-path before rectifying?
(pre-de-emphasis)
Analogue Signal Processing
