DIY cable/plug problem
Started by powerplayj, October 17, 2005, 09:26:29 PM
powerplayj
....just put together a Mogami and Canare instrument cable using Neutrik connectors using the diagram below.
http://www.neutrik.com/images/ock/downloads/Media_1544662378.pdf
For some reason, the cables are extremely dull sounding (like I rolled back the tone on my guitar) and the output is much less with my humbucker than my single coils.  I tried a cheap cable just to make sure my guitar was not the problem and the cheap cable sounds crisp and clear.  What did I do wrong???
builds completed: boutique fuzz, rangemaster, BSIAB2, PT-80, Tonepad wah, Ross Comp, Axis Fuzz, MOSFET boost, Thunderchief, Big Muff (triangle), Mr. EQ, Dr. Boogey,  Neovibe, Dist+, EA Tremelo, ADA Flanger, RM Octavia
next build(s): ???
Processaurus
some nice cable has a semi conductive sleeve under the shield, for static crackles.  If thats touching your signal wire somewhere it will act as a resistor to ground, sucking your tone like a mofo.  You can check the resistance between tip and sleeve (without the cable plugged into anything) and it should read as an open circuit on the highest setting.  I know this because it happened to me :'(
