TBing a Guv'nor
Started by emilyandmiles, October 19, 2005, 04:43:47 PM
emilyandmiles
Anyone fancy lending a hand TBing my old Guv'nor?
I'd be dead greatful.
I've a 3PDT and pics.
niftydog
you could just search the forum and use the same ideas and principles as every other TB mod described here!
Like, this one in the FAQ section
Or is there something more specific you need help with?
niftydog
Shrimp down the pants!!!
emilyandmiles
Thanks.
I'm struggling to find the Effect and Clean ins and outs on the board.
I've tried to follow the wiring but am not familiar with the jacks (they have several solder points) and am a total novice.
The only thing I can do is solder!
Anybody willing to guide me through it?
I'll post some pics soon.
niftydog
#3
um, are you sure it isn't already TB? Which version do you have? I only have one schematic which seems to be for the original (although it's hard to tell) and it's true bypass.
If it passes a signal with no power attached (in bypass mode) then it's true bypass. Try it and let us know.
niftydog
Johan
DON'T PANIC
Penguin
on an original one you would need to remove the connection to c5 so it isnt' always connected to the input.  other than that its fine.
In a corner of the churchyard, Where the myrtle boughs entwine, Grow the roses in their poses, Fertilized by Clementine.
