Modded crybaby still affecting tone..
Started by Duke of Metal, October 19, 2005, 11:50:38 PM
Duke of Metal
hey guys,
Sorry if this topic was covered before.. but i modded my Dunlop crybaby for:
- True Bypass
- Volume/gain boost
- Adjustable vocing mod
- buffer removal
anyways.. my signal line goes:
Guitar --> Wah --> Boss NS-2 (MXR Microamp in loop) --> rack.
When i plug the wah in, it seems to add some highend, but not a "natural" sounding highend.  when i take it out, the tone gets tighter and that "un-natural" highend goes away.  This is when the wah is turned off.
anyway ideas of what can be causing this?
any info would help.
Thanks alot.
  If you're using a DPDT or 3PDT for bypass, and it's wired correctly, the signal can hardly be 'effected'..barring some strange malfunction
  buffer removal...wierd...I'd double check the switch wiring, it should 'be' a 'wire' from input to output..through the switch.
Duke of Metal
Quote from: petemoore on October 20, 2005, 02:21:17 AM
hey Pete,
Here's the diagram I used for the truebypass mod.  i used a Carling DPDT switch:
True Bypass Mod
Mine is revision G.
  Yupp the switch's 'jack' connections [the poles of the sw] go to the board *somewhere...from your problem I derive that must be the circuit...when in bypass mode, true bypass will have a connection from input jack tip to output jack tip and nowhere else.
  When I did True Bypass, I didn't follow anything except the wah schematic, found the input, and the output, and wired it for true bypass from memory...the I/O jacks to the poles, a wire across a couple throws, and the circuit I/O to the two remaining throw lugs...I think there's a diagram at AMZ and elsewhere for TBypass wiring.
Duke of Metal
Quote from: petemoore on October 20, 2005, 11:30:15 AM
Thanks Pete,
I'll try a different Crybaby Cirboard that I have here and see how it works.
by the way.. what kind of wires are recommended to use when wiring stuff like this?  I used whatever i had home and I am not sure if its the greatest quility cables.  Do the cables affect the tone anyways?
