Need help with Boss HM-2!
Started by job, October 20, 2005, 08:11:02 AM
job
I have the board and box for HM-2, but they are separated from each others. So could someone please tell me where these wires are supposed to go. I allready know that 1= hot in 6=hot out, but the wires 2,3,4,5 and 18? total mystery.
-job-
MartyMart
2 - red- 9v jack "+" connection, nearest centre of the block next to "-" pin
3 - black- input jack ground
4 - blue- 9v jack "-" connection, the centre pin ( largest point on right)
5 - yellow- input jack sleeve for power on/off
18 -purple- footswitch left side connection nearest to the box side
There you go !
Marty.
job
Thank you. But still this piece of .... wont work.
I soldered all the wires, nothing. I took my multimeter, started measuring... After a a few bad words and one beer I accidently put one probe to groud and other one point 17... And voila it worked!
So do you guys have any idea what is wrong? Could someone draw me a wiring diagram or something?
I´m just a stupid Finn who doesn´t understand too much of electronics :-\
MartyMart
Inside mine, "17" is part of a large grey multi core cable going to the "pots"
board.
Perhaps that "needs" to be grounded ?
Did it make the pedal work properly ?
If so just use a new short piece of wire connect to input jack
ground ( two black wires should be going there )
Otherwise, I can't help more .... sorry !
Marty.
job
One more question.
18/purple goes to switch. But the other wire from the switch. where does it go?
-Job-
MartyMart
I would think "ground" ... sorry It;s not with me to take another look !
I do remember It was a black lead, normally "ground" in boss pedals
M.
Khas Evets
I don't know if this helps, but here it is.
job
Thank you all.
I don´t know what i´v done wrong. This thing wont do a thing.
Hey Khas Evets could you take a photo of other ends ofthe wires? I mean on/off switch and jacks. That would be awesome.
-Job-
MartyMart
Just checked for you, "Black" lead from switch does go to input jack "ground"
which is nearest the box edge.
All other connections are as above !
All I can think of is that with several "bends" of the ribbon cable, you may have
broken No 17 or perhaps others !!
Maybe a new section of ribbon cable is needed ?
Marty.
job
Thanks a lot. Have check that too.
-job-
