NTE458
Started by petemoore, November 16, 2005, 08:57:00 PM
  I can't find pinout source, all points point to NTE, the html and pdf seem quite disabled here, I want to install a Stratoblaster...
formerMember1
hi petemoore,
i don't know if this helps, or is the same thing you have but i found this online,...
http://www.nteinc.com/specs/400to499/pdf/nte458.pdf
it takes a couple seconds too load, but eventually does  :icon_wink:
Dragonfly
Quote from: petemoore on November 16, 2005, 08:57:00 PM
theyre D-G-S, looking at the flat side...
you'll like it in the stratoblaster...mucho gain, just a bit of smooth crunch :)
  'Nice sounding hybrid FF just wasn't really harmonically rich enough.
  Stratoblaster between output and switch added rich sounding harmonics, added flexibility, I also have a LP Filter switched cap on the output...very nice.
Dragonfly
Quote from: petemoore on November 16, 2005, 11:28:54 PM
sounds cool pete....
for the heck of it, you should take a germ diode and put it between q1's emitter and ground...it adds a really cool "sponginess"...should sound great with the stratoblaster tacked on the end...
rock.
  Sounds like an EZ enough one for me to try...
  Oh I used a 68k to tame the output of the SB, I think it's just a bit much at 100k, never use all that anyway, 68k is just about right, plenty.
Dragonfly
Quote from: petemoore on November 17, 2005, 12:44:42 AM
let me know how it works for ya...
