More blathering about octave dividers and the Blue Box
Started by Mark Hammer, November 27, 2005, 05:30:36 PM
Quoteto emphasize the fundamental, rather than the 2nd harmonic...
That's not quite what I meant. If you filter first, then rectify, you get a better return on effort in filtering. Rectification introduces a blather of harmonics as well as giving you a peak every once in a while.
The way patents work, I suspect I could apply with filter first and then rectify, and get patent protection on that.
puretube
ahh - when the emphasis was on: "in front",
that`s probably to save n opamp buffers in front of the filters, which want to be driven non-interactive from a low impedance;
where n is the number of filterbands...
(the active rectifiers take care of that).
GFR
Quote from: R.G. on November 28, 2005, 03:43:00 PM
In some situations, 1/2 wave rectifying followed by AC coupling can help eliminate "spurious" zero crossings - look at the graph below.
While it's true that rectification is introducing lots of new harmonics, it can at the same time improve the fundamental to 2nd harmonic ratio (the higher order harmonics are spread out). If you want to get a pure sine wave then rectifying before filtering is no good cause then you'll have more harmonics to filter out. If on the other hand the intention is not to get a pure sine but only get rid of the unwanted zero crossings it can help.
Thanks to ImageShack for Free Image Hosting
markusw
Hi all,
was the filter bank in that Bode patent ever used in a commercially available fx or synth?
I know the reply is a bit late but since I intend to breadboard such a circuit I'm really curious  :)
At the moment I do not get what the rectifier stage at the inputs are supposed to do, even more because there is a second one after the filter. I still have to read the patent more thoroughly .....
Markus
A.S.P.
Analogue Signal Processing
markusw
A.S.P.
Quote from: markusw on January 25, 2006, 02:06:27 AM
Quote from: A.S.P. on January 24, 2006, 07:40:42 PM
yes
Would you mind sharing some more details ?  ;)
Markus
"yes" approved the following (last) sentence...  :icon_biggrin:
QuoteI still have to read the patent more thoroughly .....
markusw
Quote from: A.S.P. on January 25, 2006, 03:14:15 AM
yes
Markus
And it still is valid....
...also I still don't know whether it was ever used in an fx or maybe synth module??
Markus
A.S.P.
#28
this doesn`t finally answer your question,
but oughtta be read by aspiring time & frequency manglers:
http://www.experimentaltvcenter.org/history/tools/ttext.php3?id=1
markusw
Quote from: A.S.P. on January 25, 2006, 01:49:54 PM
Thanks for the link! Interesting read.
Markus
