Switching Question, 2 circuits - on/off - on/off and both on
Started by tskullt, November 29, 2005, 07:50:25 AM
tskullt
Hi everyone,
  I have a friend that wants a compressor and a screamer in one enclosure with three switches, individual on/off plus a switch to turn both on simultaneously.  Is there a way to do this with dpdt or 3pdt switches?  Thanks for your help.
m.
http://www.pedalenclosures.com
* make all the other pedals jealous *
tskullt
AL
Go here
http://www.generalguitargadgets.com/
Click on the "Tech Pages" link on the left.
Then click on the "Switching and Wiring" link.
Plenty of info.
AL
niftydog
frankly I would just put the two switches close enough together so I can whomp on them both at the same time!
niftydog
Shrimp down the pants!!!
SteveB
Here is a way I've done it before. I also added in a loop send & return using 2 normally closed jacks. That way you could expand the master on/off by plugging other FX in the loop like a chorus or flanger. If nothing is plugged into the loop jacks the signal continues on & back to the master bypass switch.
The only foreseeable disadvantage is that the master bypass switch must be on for anything else to work. Another note: you could add another bypass switch for the loop send & return. Pretty flexible setup. TPDT switches are shown, but LED’s left off of clarity.
Steve
