Enclosure Question
Started by LyleCaldwell, December 01, 2005, 11:24:39 PM
LyleCaldwell
I've seen some effects built with enclosures that look completely square, opposed to the Hammond boxes that have slight slopes on the edges.  Does anyone have a source for non-sloped metal (preferably aluminum) boxes?  Thanks.
What does this button do?
psionicaudio.com
Joecool85
What about the aluminum enclosures radioshack sells?
Life is what you make it.
https://www.ssguitar.com
petemoore
  I like my RACO's for super cheep. You have to glue the punchouts with JB weld or really good epoxy for drilling. They're super solid and square.
  Those RS Boxes...I have a few, but I lowered the top, cut them down to flatter looking. I dont like they are so light the cable tip's 'em over/other things about them like the way they screw together, and the sides bend the paint off when opening/closing them. They're kinda cool, and shielded, drill like butter, but the RACO's are more to my liking.
MartyMart
A friend of mine is looking into having some "Boss shape" pedals made up.
de-cast with the same removable botom plate.
Top would have the "slope" but not the large foor pad/switch, so you can
wire with a DPDT etc
He's aiming for about 1cm wider 1cm higher and 2 cm longer, just for a bit more room.
I'll let everyone know if it comes to anything ..
MM.
pyrop
How 'bout casting your own.... can be done
http://www.backyardmetalcasting.com/
I have something similar to the flowerpot crucible furnace!! but have yet to make any effects enclosures just a few odds and ends. I use the lostfoam method (search google) using expanded foam, a resistance wire foam saw and a hot glue gun. U can make em nearly any shape you wont. A warning though molten metal can be just as dangerous as mains AC.
pyrop  :o
Steben
Quote from: MartyMart on December 02, 2005, 04:23:39 AM
MM.
Looks like competition for the Hairforce One boxes of that nice Frenchman.
MartyMart
Quote from: Steben on December 02, 2005, 05:10:49 AM
I bought a couple, the PITA is that that it has the bottom connected to the sides, so
your jacks and pots are on two separate surfaces ... crap for using a battery when
you need to 'get in" the thing !! but fine for PSU only ...
Hopefully, these will be "Boss" shape, bigger and have a "normal" bottom plate  :D
To be honest, they will look more like Ibanez "8" series boxes .... :D
MM.
Steben
Ok, true. Unless you drill a battery hatch.
