weird boss problem please help
Started by cmat, December 02, 2005, 10:48:10 PM
Paul Marossy
QuoteIt's almost as if they were expecting the power supply to provide 12 volts instead of 9.
Could be. Maybe it's designed that way on purpose? A lot of "9V" wall warts will put out a lot higher voltage if they are they are lightly loaded. In other words, a 500mA 9VDC wall wart is going to put a lot higher voltage than 9V with a 20mA load connected to it. If you put a 500mA load on it, your going to see closer to 9V.  If that is the case, why didn't hey just use a 9V zener or something?  :icon_confused:
johngreene
From what I've read, the ACA supply is unregulated so it no doubt varies greatly with load. But as the original poster wrote earlier, it is a 12 V wall wart.
--john
Paul Marossy
QuoteFrom what I've read, the ACA supply is unregulated so it no doubt varies greatly with load. But as the original poster wrote earlier, it is a 12 V wall wart.
Hmm, that is weird. I keep thinking corroded power jack or something. I had a similar problem once due to a corroded power jack, but it affected both the battery and the wall wart power supply...
cmat
John Greene you were exactly correct!  120 ohm was perfect. That was my problem.  I would not thought that the mods would have caused that.  Good work!  ;D
Paul Marossy
Quote from: cmat on December 04, 2005, 10:54:10 PM
Interesting. Glad that you got it fixed.  :icon_cool:
cmat
