Make a spst switch into an spdt
Started by Distortional, December 08, 2005, 06:37:22 AM
Distortional
How would one go around doing this in an easy simple cheap circuit. What I need to do is, have a push switch that when pushed goes through my distortion circuit, and when not pushed it simply misses out the circuit going along a straight wire to the output.
Help?
JimRayden
Hmm, the title and the post tell totally dofferent things.
You want to buy a dpst switch, that makes for a LED-less true bypass and would be momentary, as you described. You can't do that with a common stompbox switch, you'll have to search around for the momentary footswitch.
Jimbo
Distortional
Well, I have a spst switch. I just realised that if I used it in my circuit, when I turned the circuit on, the guitar sound would be distorted, when I turned it off, it wouldn't do anything. I wanted, on: distortion, off: clean. That wont happen. So I figured I needed a switch, that will switch between one wire between the input and output and one that will go to my distortion circuit. When i am play, I don't want to have to fiddle around with a switch, I want a button.
So I need a to make the SPST switch I already own, switch between 2 different circuits basically. How?
JimRayden
There is one possibility - a relay. Search on the net for some info on them, they're pretty nifty gadgets.
Jimbo
niftydog
wait a second here...
Clarify what you need, you're a bit all over the shop at the moment!  :icon_biggrin:
Is it;
one press = distorted
another press = clean
Well, that's just a bypass switch isn't it?
Or do you want;
press down = distorted
lift off = clean
Or something else?
niftydog
Shrimp down the pants!!!
“It also sounded something like the movement of furniture, which He
hadn't even created yet, and He was not so pleased.” God (aka Tony Levin)
JimRayden
Quote from: niftydog on December 08, 2005, 07:31:05 AM
Or do you want;
lift off = clean
I'm electing this one. :)
Jimbo
Roobin
In that case, you'd want a Momentary switch, which doesn't click on/off. When you push it down, it does one thing, when you don't it does the other.
However, wouldn't it be easier to use a normal dpdt switch? (or 3pdt if you can buy them)
Hav a look at http://www.generalguitargadgets.com/index.php?option=content&task=category&sectionid=4&id=23&Itemid=200 and GEO for more info, or search this forum.
Paul Marossy
QuoteIn that case, you'd want a Momentary switch, which doesn't click on/off.
Actually, some types do. I sold RG a bunch of SPDT momentary switches a while back that clicked almost just like a Carling DPDT switch does. But, generally speaking, you're right, they don't click.  :icon_wink:
Distortional
Nah, I think what i'm looking for is that SPDT relay. That's exactly it pretty much :D Thanks, now to find it for cheap in the UK.
Hal
what are you trying to achieve?  It kinda sounds like you're a little confused...we can help with more infor... :icon_question:
Marcos - Munky
If you want the first thing that Niftydog said (press once: distortion, press again: clean), you can do it with a SPST switch plus a few components (1 or 2 ICs, a few caps and resistors). Just tell if you have a momentary SPST (press: the lugs connect, lift: the lugs disconnect) or a non-momentary SPST (press: the lugs connect, press again: the lugs disconnect). I have a link with a few electronic bypass schematics, but need to know which kind of switch do you have.
