I'm building a Schaller "Bow Wow Yoy Yoy" Clone!
Started by Paul Marossy, December 09, 2005, 01:39:10 PM
Paul Marossy
I designed a PCB layout last night that is based on using Fasel inductors. I'm going to etch it this weekend and populate it as much as I can. The PCB will be the same dimensions as the 80s Cry Baby wah boards (roughly 3"x2"), so all that will have to be done is to pop it into a CryBaby shell. I'll keep y'all posted on my progress.
I have a couple of questions for anyone who might know the answer:
1. Where in the world do I get a heavy duty reverse log pot from?! Would a Dunlop Hot Potz II work OK?
2. Transistors. Anyone know what transistors were used in the original (or what should be used)?
Thanks!  :icon_cool:
EDIT: OK, according to this schematic http://www.diystompboxes.com/pedals/schall.gif , the transistors are BC239s. (I don't know if the schematic is correct, but I used one from another source that I trust)
A.S.P.
somebody asked a while ago here, whether there was need for those pots
(NOS 100k neglog with mounted pinion from the OEM)
there were no replies...
Analogue Signal Processing
Ry
I can't answer your questions but I'm really interested in this project.  I can't wait to see and hear how it turns out!
Ry
Paul Marossy
#3
Well, here's a picture of the etched PCB:
My PCB design appears to have no flaws that I am aware of. It's got quite an interesting sound. It seems to be more of a variable filter than a wah type pedal, but then again, I don't have a reverse log pot to try with the circuit. It's really hard to describe what it sounds like. For now, I used a couple of 600mH inductors that I pulled from an old Realistic graphic EQ, but I guess I'll get a couple of Fasels to put in the circuit to see how that sounds. I was also playing with the sweep cap values, and I can't really decide what sounds best - I've tried the 0.0047uF cap as specified on the schematic, a 0.01uF, 0.0022uF, 0.68uF and a 0.1uF - they all sound different and they all could be useable depending on what you wanted. I used a trio of 2N5089s with an Hfe of over 800. But I think the biggest problem I have is the pot. I've got to figure out something for that...
I'll post my PCB layout shortly for the curious. I think it will just fit in a CryBaby enclosure, but I haven't verified that yet. It's made from that crappy RS PCB kit that I refer to here: http://www.diystompboxes.com/smfforum/index.php?topic=39838.0
Paul Marossy
OK, here's the PCB layout. It prints out slightly smaller than actual size, but it should be close enough to use without any real problems.
puretube
Quote from: A.S.P. on December 09, 2005, 03:23:03 PM
http://www.diystompboxes.com/smfforum/index.php?topic=24043.msg155054#msg155054
Paul Marossy
I guess this would be one case where you would need one of those pots.
alfafalfa
Hi Paul,
I watched this post with interest because I had one of these pedals back in 1968 and always regretted selling it.  Could you post some clips and I'll see if I can remember the sound. I sure do recollect the joy joy sound  but unfortunately it wasn't very usable.
This was one of those wahs which could give me endless sustain on a certain frequency together with my vox ac 30..
My modern Crybaby  535 has a sweep which is much too wide.
Recently I've made my own inductor which is quite good but not exactly it.
So what I would like to know is where can I get one of those  100 K neg log pots ?
Regards, Alf
Paul Marossy
Hi Alf, ok we'll do that after I redesign the PCB. It won't fit unless you lay the inductors down on their backs, but I'm not totally happy with the layout at the moment. I'm going to do a GCB-95 style PCB, I think that will work out better in this case. Stay tuned...
Phorhas
Hi Paul, I saw your post and opened up my wau-wau. an original schaller, and it has 3 BC239c indeed. good luck :)
Electron Pusher
Paul Marossy
Thanks for the tip on the transistors, Phorhas.
I've got a revised PCB layout here. I probably won't be able to verify that it works OK for a week or so. Anyhow, this one should just squeak by as far as the inductors fitting in a CryBaby wah shell is concerned...
Paul Marossy
OK, I built it per my new layout and it's fully functional as designed. It should now also just fit in the standard CryBaby wah shell - it's basically a drop-in replacement for the GCB-95 PCB. Here's a couple of pics of the new PCB:
Now, if I could only get my hands on a 100K reverse log pot...  :icon_confused:
puretube
Paul: sorry, haven`t found the bag of goodies yet... (next week).
only have the one I played with last year at hand:
pot won`t come for X-mas, but for the new year...
Paul Marossy
Thanks puretube! I'll put it on the back burner for a couple of weeks.  :icon_cool:
A.S.P.
anyone tried BC 239 B in this or similar circuits?
just found an old box with 2000 of those NOS made by Siemens.
Paul Marossy
Wouldn't the BC239B be lower gain than the BC239C, or is it the other way around? I can't remember...
A.S.P.
Jaicen_solo
FWIW, I know of a source for reverse log pots in the Netherlands if you're struggling.
They accept credit cards and ship internationally. I'm hoping to get some for my Neovibe when I get round to it.
Paul Marossy
Quoteyes, lower...
They might work if they are in the higher end, speaking of Hfe. The Bs range from about 200-450 and the Cs range from about 400-800.
puretube
Ouff - finally found`em... (they were in a box between the "speaker department",
where I hadn`t searched before...)
you want the one with mounted cog-wheel, right?
or rather the "naked" one?
or both?  :icon_wink:
the original NOS pre-wired for Schaller Volume pedals 100k neg log pot...
will go to the post-office on monday.
:icon_smile:
