custom made enclosures?
Started by no one ever, December 26, 2005, 08:43:28 PM
no one ever
i need a 6 x 4 x 1.75" box... any suggestions?
(chk chk chk)
SolderBoy
There's  a hammond one that's pretty close - 145x95x45mm
no one ever
(chk chk chk)
mojotron
Quote from: no one ever on December 28, 2005, 12:19:21 AM
... prod #?
I really like the Hammond 1590DD it's about that size IIRC... you can search mouser for "Hammond 1590DD" to get the details, there are a number of Hammond 1590 enclosures if you search their cataloge.
Dave_B
Help build our Wiki!
Speeddemon
Man, that 1590N1 enclosure should be sold by DIY/builder sites. I find it has some ideal dimensions:
121mm x 66mm x 35mm.
It's 1cm (0.4") longer than a 1590B, meaning easier room for a battery or for a slightly larger PCB.
It's 6mm (0,25") wider than a 1590B, meaning it's easier for larger enclosed jacks to oppose, possibly with room for a LED holder in between.
It's about 7mm higher, a great size to mount small PCB's vertically, for a battery to have ample room or for PCB's to be above the potmeters.
I know the 125-B enclosures (from Taiwan) come close, but for some reason those seem TOO high for me.
The ultimate enclosure would be 120mm x 65mm x 30mm (without bottom plate).
Meanwhile @ TGP:
"I was especially put off by the religious banterings written inside the LDO pedal. I guess he felt it was necessary to thank God that someone payed $389 for his tubescreamer!"
Connoisseur of Distortion
i think 125-b IS the ultimate enclosure  ;D
it looks too big, but it's actually very easy to step on...
