manual plus LFO
Started by markphaser, December 27, 2005, 10:10:49 PM
markphaser
 I have seen some flangers with the manual and LFO at the same time
What does the Manual control do to the LFO circuit?
The Manual parameter changes the time constant? controls the notches/peaks? moves the notches/peaks up and down?
With the LFO sweeping up and down a voltage with DC offset. The LFO changes the time constant but the manual parameter
changes the time constant also if they are both the LFO and manual are on at the same time what happens?
Whats the difference between DC offseting the LFO VS using a manual parameter with the LFO?
QuoteWhat does the Manual control do to the LFO circuit?
Mostly it replaces it.
QuoteThe Manual parameter changes the time constant?
No.
QuoteControls the notches/peaks?
Yes.
Quotemoves the notches/peaks up and down?
Yes.
QuoteWith the LFO sweeping up and down a voltage with DC offset. The LFO changes the time constant but the manual parameter
No.
QuoteWhats the difference between DC offseting the LFO VS using a manual parameter with the LFO?
The offset of the LFO causes the LFO to sweep through a different range. The manual replaces the LFO - no sweeping except when you turn the manual knob.
markphaser
Thanks for the help
The Boss Flanger BF-2 has the manual parameter and LFO on at the same time
Boss Flanger schematic
http://www.geocities.com/j4_student/Bf2.gif
See how the manual parameter is on at the same time the LFO is sweeping
The offset of the LFO causes the LFO to sweep through a different range doesn't the manual parameter do this also?
It seems like the maual parameter is the offset?
I thought the phase filter network sets the range? but the LFO offset sets the range also?
