Low leakage Diode
Started by mr. man, January 06, 2006, 06:06:30 PM
mr. man
Hi,
I was reading the GEO article on the millenium bypass and it says not to use any old diode as a low leakage diode. In that case, what should I use? I'm not sure I understood the article. I am making this board:
http://www.geofex.com/Article_Folders/Millenium/mill2bd.gif
Use the collector-base junction of an ordinary NPN transistor. Cut off the emitter, use the base as the anode, the collector as the cathode.
mr. man
That simple huh?
Thanks for that  ;)
