Whooshing sound....
Started by seanm, January 11, 2006, 12:19:17 AM
seanm
While at practice tonight I started getting a whooshing sound from my rig. I put a Boss TU-2 in front of the preamp and that seemed to solve the problem. However, the TU-2 had a very low battery and went dead. It "ran" about 2 hours with the battery too weak to light the LED but then started making noise. When I plugged straight back into the preamp everything was fine.
I couldn't try anything since I did not want to disrupt the practice. Some info:
  • Preamp design here: http://seanm.ca/stomp/preamp.html
  • I use a cheap 24V wall wart that produces 30V under load from the preamp
  • I use an LM7824 to regulate the voltage down to 24V.
  • The ground wire in the basement is floating  :icon_eek:
  • I don't think heat was a problem since the preamp felt cool to the touch.
I am not sure the problem is the preamp. Thoughts?
