Cool Cicuit to Add Wierdness to LDR-Based Pedals
Started by erix, January 12, 2006, 01:37:42 PM
erix
I saw this one in December "Nuts-n-Volts" mag. It simulates a flickering candle with a single LED.
A constantly varying voltage is supplied to the LED by four oscillators built from a single 4093, each running at different speeds.
The article showed fixed resistors controlling the freq. (1M, 470k, 270k, 100k for 1Hz, 2Hz, 4Hz, and 10Hz respectively) but I drew them as variable.
R18 biases the LED so it never goes completely dark, should probably be a pot labeled "Sensitivity"
I imagine you might be able to get that cool Johnny Marr Tremolo thing happening with all four oscillators running almost the same freq.?
Thoughts?
nelson
Looks cool, is it square wave though?
EDIT: looking at the datasheet it is a squarewave.
My project site
Winner of Mar 2009 FX-X
birt
so if you put this on an idiot wah you can get a crazy idiot wah?
http://www.last.fm/user/birt/
Quote from: birt on January 12, 2006, 03:34:49 PM
probably yeah, I've added something similar to my uglyface (which I'll be posting about soon :) )and you get some pretty good noises, kind of like a sample and hold filter. There's an article on GEO about this sort of random LFO, or have a look at Ken Stone's psycho LFO over at http://www.cgs.synth.net/, it's in the modules section.
  Well yes, that'd be cool.
  I'd typed about dual LFO, series or parallel, [to get away from the ~ normal sweep waveshapes into something less repetetive].
  "Series">One LFO controlling the speed of the other LFO, making it's cycling accellerate/deaccelerate.
  "Parallel"> Two LFO's at different rates powering 1 LED per LDR into peak brightness-es.
  "Parallel II" two LED's per LDR per phase stage, each bright/dark cycling happening at a different rate Via 2 LFO's...each phase stage would have 2 LED's 'blinking' at different rates and peak brightnesses, shining on 1 LDR...
  This circuit^ would do a similar job?...it looks like it could be capable of manipulating LDR Resistance in 'odd' ways...
object88
Quote from: nelson on January 12, 2006, 01:51:22 PM
You could apply a gentle (3db/oct? 6db?) LPF to round it off to a triangle.
