More thinking on the lm3886 guitar amp
Started by Joecool85, January 24, 2006, 08:30:28 PM
Joecool85
I already figured I want to it like this:
In
3 band passive EQ
LBP-1 preamp
lm3886
Out
Now, here is the question, originally I was going to leave both the volume control on the preamp and the lm3886, now I changed my mind and one will have a trim pot.  But which one?  Any ideas to which would give better results?  Trimpot the LBP-1 to make up for loss in the passive EQ, and then control volume via pot on the lm3886, or trimpot the lm3886 and control volume via LBP-1?
Right now I'm thinking trimpot the preamp and adjust volume directly on the poweramp section...
Life is what you make it.
https://www.ssguitar.com
ninoman123
Wire them both up with pots. Play with it awhile. If you find out that one should be a trim pot then make it one.
Joecool85
Well, thats probably what I'll do anyway, I just wanted to know what you guys thought.
MR COFFEE
The overdrive charactristics of the LM3886 are horrible. It does not clip like a well-behaved guitar amp - it generates AWFUL spikes (note that the overload protection scheme is appropriately named).
You will regret it if you don't reconsider your design.
Don't mean to sound negative - just the facts... check out the scope traces on the LM3886 data sheet and you'll see what I mean. DON'T GO THERE. IT WILL TURN YOU OFF TO DIY FOREVER.
DIY CAN SOUND GREAT.
Bart
ninoman123
Nothing is wrong with his design. Hes simple running pedals in front of the amp. Hes not overloading the amp at all.
Joecool85
Trust me, I know all about the built in SPiKe protection.  I'm not doing this to overdrive it, the LPB-1 is there to regain lost db from the passive EQ I have in there.  I will either have it set up with a trimpot so that the LPB-1 is basically getting the signal back to guitar strength, or I will use a trimpot to keep the poweramp "turned down" and turn up the preamp.  Like I posted earlier, I think that trimpotting the preamp to a lowlevel, and then using the pot on the lm3886 to control volume will probably be wisest.  We'll see.
The other cool thing about doing it that way is that I could probably work it out well enough that with the preamp down enough, I could crank the volume on the lm3886 to full (or almost full) without kicking in the SPiKe protection.  That way I don't have to worry about it, I can just plug in and play.
RDV
You'll probably want a buffer in front of the EQ also.
RDV
Joecool85
I was thinking about that too.  One kinda like what is on the ruby maybe?  Now, even though I had thought of it, I didn't know what exactly it would help with...I know it has something to do with input impendance or something.
RDV
Quote from: Joecool85 on January 25, 2006, 07:49:47 AM
That one would work fine.
Yes, and to drive the tonestack.
RDV
Joecool85
Now, if I put in a buffer like that, would I need the LBP-1 preamp or no?
Also, with the buffer, will it accept pedals pretty well?
I'm not building any sort of OD/distortion into the amp, its just a clean poweramp with a 3 band eq that I can plug pedals into  :icon_mrgreen:
RDV
Quote from: Joecool85 on January 25, 2006, 09:06:26 AM
Put buffer into the search and start reading, but the answers to your questions are Yes and Yes. A buffer does just that, it buffers, or acts as a line driver.
READ.
RDV
