Dr Boogey ... debugged and great !
Started by MartyMart, January 26, 2006, 03:20:03 PM
Scruffie
Quote from: askwho69 on January 30, 2011, 08:54:06 AM
What happend to this  :icon_question: i was waiting foe this :D
Still waiting on a few parts, had to postpone an order while I moved so it's taken a while.
I've checked the layout over though and i'd say just build it...
elshiftos
#82
Quote from: Scruffie on December 19, 2010, 03:51:58 PM
Here we go, I did a PCB Layout for this to fit a 1590B with Onboard Pots (Mounted on back of the board) With the Big Muff Tone Stack (Trimmer rather than Pot, Could wire a pot up though, or use a Trimmer Knob).
Values as Follows For it
TR5 - 1M
R15 - 4.7k
C19 - 6.8n
C20 - 6.8n
Change R16 Between
10k - Scooped
47k - Flat Mids
100k - Mids Hump
Apologies if I'm overlooking the obvious, but is there a schematic for the above tone section? Also, 1M tone pot? :icon_eek:
Ok, I'll engage brain before posting:
R15 + 6n8 = LPF, R16 + 6n8 = HPF, 1M tone pot blends. Correct?
TIA
Scruffie
Quote from: elshiftos on May 02, 2011, 01:22:35 PM
TR5 - 1M
R15 - 4.7k
C19 - 6.8n
C20 - 6.8n
Change R16 Between
10k - Scooped
47k - Flat Mids
100k - Mids Hump
TIA
Nah no schematic, I just tacked on a Big Muff TS where the Tonestackless schematic left off.
Use whatever values you want, I changed those in the end, can't recall what to at the moment.
Scruffie
Aha! Found what I used -
R16 (Switchable)
Scooped - 4.7k
Flat - 22k
Hump 47k
DPDT On/Off/On 47k Center, 47k One Side, 4.7k Other
C19 22n
R15 22k
C20 22n
Trim 100k Lin
That Clear It Up? And Yes you're right in your assumption of HPF & LPF.
Scruffie
Right... back with a proper build report on this one...
The Good news, it sounds great and there is no oscillation at any setting I could find, i'm not too keen on the multi turn trimmers for biasing by ear as they take alot of turns but that's a minor gripe and it sounded pretty nice at most settings anyway, perhaps not as heavy as a full stacked version because of the lack of tone shaping but still really nice.
Changes I would make would be to add a small cap across R15 so that you don't loose all the treble when you roll the tone stack down to the bass side and I do find the 3 way toggle to be pretty handy for different situations as it helps make up for that lack of tone shaping control.
The Bad news... there are 3 fixes needed to my layout (I'll update the layout and repost it here later, i'm going to add one or two things to it anyway).
If you built the first version you need to -
a) The easiest one, cut the trace connecting C2 & C3 and then connect the end you just cut of C2 to the Other side of C3.
b) Cut the Trace between C8 & R10 and then connect the now cut end of R10 to the other side of C8
c) The most complex fix (Not that hard though) Cut the trace going from the input up to Q1 Source (Leaving in tact the trace that runs from the source to R2 & C1) Remove C13 and Jumper Over it, then place C13 across the Gate and Source of Q1
And that's all that's required! (I say it like that, my board is now a mess of jumpers and lifted traces... but that was my own fault).
As my post above, I quite like that tone stack in this, of course you can forego the tone stack and just jumper from R14 to VOL Lug 3 (Hmm... perhaps adding a tonestack disengage switch could be a useful mod... if there's room i'll add pads on the new layout.
One last thing, it gets very tight on spots on the layout, so don't do what I did and have to keep lifting up the board mounted pots to get underneath to fix things cause that's how you end up with a bunch of lifted traces  :icon_redface:
Thanks again for Rob for providing me with my late christmas present  :icon_mrgreen: and sorry for taking so long to get this build report up.
Conclusion... awesome little pedal and in a 1590B!
Scruffie
Okay, ive redone the layout now to include pads to either have the tone stack switchable in and out of the circuit, to bypass it or you can just jumper them and have the tone stack in at all times.
I've also corrected the errors, changed the box cap 1uFs to Electros (Sod ordering special box caps) made a couple of places a little less tight and added in a shelve filter cap for the tone control so when you roll the bass down you don't loose all the highs.
Now... how do I upload PDFs...
DonB
Quote from: Scruffie on May 05, 2011, 08:41:22 PM
R16 (Switchable)
Scooped - 4.7k
Flat - 22k
Hump 47k
C19 22n
R15 22k
C20 22n
Trim 100k Lin
How do you wire something like that?
Scruffie
Quote from: DonB on May 30, 2011, 05:05:46 PM
R16 (Switchable)
Scooped - 4.7k
Flat - 22k
Hump 47k
C19 22n
R15 22k
C20 22n
Trim 100k Lin
A 3-Way DPDT, The middle position is always connected so with a resistor either side they add in parallell so you work out the middle value plus the other sides value to see what they would equal, the middle should always be the largest value (with resistors, caps work the other way) so you have 47k center, you add 47k on the other side and you get close enough to 22k, other side you have a 4.7k and you end up with close enough to 4.7k.
Make sense?
(Appologies for spelling, had a few drinks  :icon_mrgreen: )
askwho69
Scruffie! do have the final schematic so that i can  make a layout out of it :D
"To live is to die"
Scruffie
Quote from: askwho69 on May 30, 2011, 11:01:37 PM
No Schematic i'm afraid, take the schematic at the start of this thread and slip a Big Muff (or whatever) tone stack before the volume control, that's all I did.
askwho69
ohh ok how about the schematic of the tonestack"your modification" ? :D that may help :D
"To live is to die"
meffcio
#92
Wait, wait. Sorry for my absence. So, did you redo your layout? Or am I misunderstanding?
If so, I suggest you to send the file(s) here: http://www.mediafire.com/ It's simple, everything is shown.
I'm getting back to DIY, so I'll soon be able to see how the circuit works.
Also, did you think about doing something like that
from that? :D
[EDIT]
And as the topic lacks it, here's the BOM:
(Tonestackless Boogey)
C1 1uF
C2 22nF
C3 2.2nF
C4 1nF
C5 20pF
C6 1uF
C7 22nF
C8 22nF
C9 1uF
C10 27nF
C11 2.2nF
C12 2.2nF
C13 220pF
C14 220pF
C15 220pF
C16 100uF
C17 5nF
C18 1nF
Q1 J201
Q2 J201
Q3 J201
Q4 J201
R1 1M
R2 1.8K
R3 2.2M
R4 680K
R5 470K
R6 1.8K
R7 470K
R8 1M
R9 3.9K
R10 330K
R11 220K
R12 1.8K
R13 15K
R14 15K
TRIM1 100K
TRIM2 100K
TRIM3 100K
TRIM4 100K
GAIN 1M-A
VOLUME 100K-A
(Added with Scruffie's version; from the post on 2nd page - to be corrected)
TR5 - 1M
R15 - 4.7k
C19 - 6.8nF
C20 - 6.8nF
Change R16 Between
10k - Scooped
47k - Flat Mids
100k - Mids Hump
Scruffie
I did a different version with a Baxandall Tone Stack, have a search.
