question about dual op-amps in general
Started by tennisdude, January 26, 2006, 11:44:08 PM
tennisdude
hey guys,
total newb when it comes to opamps (or electronics theory in general :D )
i was checking out this schematic for a chool looking pedal called the Dr. Quack
http://www.muzique.com/schem/quack.gif
Tell me if im reading the IC right:
(using a tl072 as my opamp)
for IC1a, the + and - in the triangle represent pins 3 and 2, respectively (In+, In -)
the tip of the triangle represents pin 1 (out1)
and the ground symbol coming from the middle of the triangle represents grounding pin 4
for IC1b the + and - represent pins 5 and 6, the tip represents pin 7, and i should ground pin 8?
Thanks alot for the help
??? ??? 8)
John
The Tone God
Always consult the ever knowing datasheet:
http://focus.ti.com/lit/ds/symlink/tl071a.pdf
BTW pin 8 is power, pin 4 is ground. ;)
Andrew
qwixzh
yup , pin 8 should be the positive (+) supply... :icon_biggrin:
tennisdude
