Fuzzface or Hornet?
Started by rockgardenlove, February 28, 2006, 11:41:24 PM
rockgardenlove
Dunno which to do...I'm tempted to build the Hornet because of the tweakability and reliability of silicon(tempwise etc), but then the Fuzzface is just so classic.  What do you think about these two projects?
phaeton
Build them both, sandwich them together and call it a Fuzzornet.
Stark Raving Mad Scientist
KRK
 ;D Couldn't resist offering hornyface as a name
RLBJR65
If your thinking of building a Fuzz Face you should check out R.G. Keen's FF Tech page.
http://www.geofex.com/Article_Folders/fuzzface/fftech.htm
Really good info.
Richard
Richard Boop
aron
I like the Hornet and it is basically a Fuzz Face, but the 5K pot is suspect after looking at it after all these years.
It should be wired like Gus wired it here:
http://www.diystompboxes.com/pedals/3tran.JPG
Weird man.
brett
Hi.
Another improvement to this design is to use a 2N2369A (=PN2369A) as Q2 (Q1 in a 2 transistor FF) and do away with the 100 ohm resistor on the emitter.
This provides a little of the germanium tone by making the clipping more asymetric, as per the Ge FFs.
cheers
Brett Robinson
