Finished my lm3886
Started by Joecool85, March 07, 2006, 07:48:15 PM
Joecool85
It's not a wicked looker, but its freakin' loud!
Life is what you make it.
https://www.ssguitar.com
Connoisseur of Distortion
holy crap, that much heatsink??? it's massive!!!
BrianGT
Looks good!  It is overheatsinked, but it is definately better than having too little :)  Also allows for adding a lot more modules to it in the future for more power.
Good job!
Brian
Joecool85
Yeah, I figured I would get the huge heatsink since it was cheap on eBay, and that way I can have like...2-4 chips on there no problem.  It barely gets luke warm right now  :icon_twisted:
I also used a 250va transformer which is overkill for that too.
  Hard to tell how big those pliers are..
 Perhaps you could give the amp dimensions so I can get a better idea what size.
 Awesome...loud...that's always nice in case you're wanting headroom... 8).
 PDCool. Looks like a nice item to have.
Joecool85
The enclosure is 12x8x4.  That doesn't include the heatsink.
i intend to make one of these soon. my heatsink is much smaller, but probably sufficient. If not, i have a little fan to top it off!  :)
would an 80 VA transformer be suitable? i expect a resounding "no", but...
Joecool85
I'd say its too small.  RDV got away with a 96va, but I personally recommend no smaller than a 160va.  All that will happen though is that you won't get full power, and if you push it hard enough you will overheat the transformer and kill it...but if it's what you got and you don't want to buy one, I'd give it a shot.  How many volts is it?
i'll be running the tranny at 30 V, 2+2/3 A. So, post rectification, i'll have +/- 42 V rails. if i understand this data sheet right, that means it'll want to kick out 80 watts? ouch. maybe i should find a new transformer...
RDV
#9
Quote from: BrianGT on March 07, 2006, 08:02:28 PM
Good job!
Brian
It's not really oversinked for a guitar amp, for a stereo amp, yes. I probably pushed him in that direction. If he wants to add another LM3886 though he's set and ready heatsink and transformer-wise.
Regards
RDV
RDV
#10
Quote from: Connoisseur of Distortion on March 07, 2006, 10:18:08 PM
I used a 36VCT 56VA tranny at first and it was as loud as a practice amp should ever be. R.G. Keen has said that 1VA per watt will work in most cases. It's not ideal, but you will get sound. It never did heat up that much either, though I didn't try to gig with it or anything.
Oh, and don't skimp on the heatsink if you plan to play guitar through it. Just trying to save you some trouble later. It doesn't have to be as big as Joecool used, but it should bigger than a CPU heatsink(even w/ a fan).
RDV
RDV
Joecool85
Thanks RDV, I'm happy with it.
brad
Did you use thermal grease between the chip and the heatsink?  I haven't tried it yet, but I figure a heatsink is only as good as the contact between itself and the surface it's supposed to be cooling.
Joecool85
Yup.  Silicon stuff from radioshack.
