Rebote 2.5 debugging, please help
Started by bancika, March 11, 2006, 02:15:28 PM
bancika
Hi,
I just finished rebote 2.5 delay with tonepad.com PCB layout (board made by myself). The problem is I get dry sound no matter if pedal is on or off.
Here are voltages:
delay chip
1: 5.22
2: 2.6
3,4: 0
5: 2.5
6: 2.6
7: 0.22
8: 0.64
9-16: from 2.5 to 2.6V all of them
opamp
1: 4.74
2: 4.7
3: 4.7
4: 0
5: 3.8
6: 4.74
7: 4.74
8: 9.4
5V regulator gives about 5.2V and power supply is 9V regulated with 220 and 100uF filter caps, gives 9-9.4V
Any ideas?
KRK
I posted the following, may be worth keeping an eye on that thread as well.
http://www.elixant.com/~stompbox/smfforum/index.php?topic=43054.0
I'm keeping an eye on this one too.
Mihkel
I had the same problem, never found out what caused it but after rebuilding using the same PCB it worked.
bancika
update: actually, sound that comes out when pedal is on is weaker than when bypassed, if it helps.
