Matching Diodes...
Started by LyleCaldwell, March 11, 2006, 07:14:36 PM
LyleCaldwell
I need some diodes with a forward current of 600ma.  Do I need to order a whole bunch and then match them or is there a source for diodes with tight tolerances?  The diode shown in the 78xx datasheet is a 1N4148, but looking at its datasheet it shows a forward current of 150ma.
I'm using the diode in question on pin 2 of a 7809 to get an output of 9.6vdc.
What does this button do?
psionicaudio.com
Paul Perry (Frostwave)
The thing is, diodes have a different foward current at different voltages. I don't know what current is goingto be flowing thru the ground pin that you are trying to jackup.. something pretty low I bet... Isuggest trying 1, 2 and even 3 diodes in series on the leg to ground & seeing what happens, under whatever load you are driving.
I can't thinkof many places where 600mV on a power rail is going to matter, anyway!
cd
FAR easier to get yourself an LM317 and a trimpot, and trim it down to whatever precise voltage you need.
brett
Hi.
Your application doesn't need close matching.
But instead of 1N4148s, use a 1N4001/4/7.  They'll handle a fair bit of continmuous current and heat (about 1 amp and 1W, I think), and a lot more on a low duty cycle (around 10 amps at 2% duty in a couple of circuits where I use them).
cheers
Brett Robinson
amz-fx
Quote from: LyleCaldwell on March 11, 2006, 07:14:36 PM
You don't need to worry about selecting the device...  but if it is a 7809 then you probably need a 1N4001 to handle the max current (to be safe).
regards, Jack
LyleCaldwell
Thanks all - I went ahead and switched to an LM317.
psionicaudio.com
