Jawari Layout
Started by Austin73, March 14, 2006, 05:51:32 AM
Austin73
Has anybody got a pef/vero layout for a jawari pedal?
I have the pcb layout but don't have the facilities to make one at the moment
Cheers
Austin
Bazz Fuss, Red LLama, Harmonic Jerkulator, LoFo MoFo, NPN Boost, Bronx Cheer, AB Box, Dual Loop, Crash Sync
insideout
dunno if you have made any progress...I did this stripboard that worked first time  :D
http://insideloop.googlepages.com/electronics
hubble
i have one for vero (unverified) but you would either have to leave the transformer hanging or drill some slots to mount it
markm
Where's the PCB layout you have?
goodrevdoc
IIRC, there is one over at GGG, under noise makers.
markm
Oh yeah, that's right.
I knew I saw it somewhere.
Thank you!
Pushtone
The Jawari is simple enough to just place the layout over a perf board and use as a guide.
You could even blow it up on a photocopier if it looks too tight inbetween traces.
I've tried this. It makes doing perf so easy it feels like cheating.
Paul Marossy
I have a PCB layout that I made about four years ago here: http://www.diyguitarist.com/PDF_Files/JawariPCB.pdf
Austin73
Almost finished making this sucker but noticed there are no cuts under the 2 1n34 diodes is this correct?
Can somebody please check asap as I have only got 30 mins before i have to go to work
Cheers
Aus
hubble
if you're talking about the vero layout - yes there are, its hard to see them but they are there.
markm
Great job Pushtone,
That's not cheating......that's ingenuity my boy!!
Paul Marossy
QuoteGreat job Pushtone,
I used a similar method on one of my builds. It makes life easier.  :icon_cool:
