Francisco CE-2 issue: background noise
Started by rocker-D82, March 14, 2006, 07:09:34 PM
rocker-D82
I build this amazing chorus!
I report it here: http://www.elixant.com/~stompbox/smfforum/index.php?topic=38153.msg310919#msg310919
I have a problem. Using it with battery doesn't give me problem. I thing there's a strange background noise, but I think it was normal. When I use my power supply, my effect become unplayable. There's a 50hz cycle... to much to play!  :'(
I check C30 because i find a sort of jitter when I misure voltage to positive tip. I change it... the same beaviour! :(
I change D7 with 1N4007... same beaviour! :(
I change Q4 and Q5 from 2N5088 to 2N5089 in order to lower noise... same beaviour! :(
Any idea? :'(
Fp-www.Tonepad.com
The problem is probably your power supply. Try another one.
www.tonepad.com : Effect PCB Layout artwork classics and originals : www.tonepad.com
rocker-D82
Quote from: rocker-D82 on March 14, 2006, 07:09:34 PM
I think the problem is another. I use this power supply with a lot of other pedals without problems. But I look a jitter on C30 (positive side) with battery, too. Can be a "broken" MN chip who introduce an eccessive power request??
