"Splitter-blend" question! HELP NEEDED! =)
Started by SpufuZ, March 16, 2006, 11:00:55 AM
SpufuZ
hello!
In this project
http://www.runoffgroove.com/splitter-blend.html
there is a small transistor circuit right after "green return".
My question is what is it there for? Is it needed?
can i just skip that part and lead the return signal right in to the "U2A" IC, same as red Return?
//david
Skreddy
Green return is set up with a polarity-reversing switch (assuming two amps are being used and that some amps are out of phase with others).  The buffer is needed for that application.
SpufuZ
Quote from: Skreddy on March 16, 2006, 11:27:58 AM
yes i know that there needs to be a buffer, but do i need the j-fet circuit before the ic-circuit!?
Theres none at red loop...
Skreddy
#3
If you want to do the polarity switching, you need the buffer in front of THAT.  If you don't need the polarity switching, just make both channels like the red side.
SpufuZ
#4
Quote from: Skreddy on March 16, 2006, 12:31:39 PM
ok! good to know! thanks.
But do i NEED the phase-inverter?  Im just going to use one of the loops for effect and the other one as a "dry" channel to be able to blend in the effect to the dry signal!
This is possible right!? And do i simply connect red send to red return and its fine?!
Would i need the phase inverter if im only to use green as Wet and Red as dry?
heres a scheme i did!
would it work?
Skreddy
In that case, you wouldn't need a return section for the straight signal.
But the phase-selector switch is still a good idea, because you really have no idea what phase the effects in the loop are going to leave your signal in or whether you might even like it better out of phase.  I'd use the RunOffGroove version anyway, just because it's so much more versatile and not really that much harder to do.
SpufuZ
so the phasing could be a good idea after all i think, but could i use some other transistor than the 2N5457? They cost so much?
Does it have to be FET? could i use a NPN like the BC547 or so?
Skreddy
2N5457's are $0.19 each at Mouser.com.   ???  A FET makes an ideal buffer because of the high input impedance.  Since you're planning to build a straight-signal/effects blender, though; you have another half of an opamp you could use as the buffer in front of the phase selector.  So you could use IC1A and IC1B for the two inputs, and IC2A as the effects-output buffer (instead of the FET) and IC2B as the phase selector.
Quote from: SpufuZ on March 16, 2006, 03:08:58 PM
SpufuZ
Quote from: Skreddy on March 16, 2006, 05:26:43 PM
hmm i dont relly understand exactly how you mean...
sorry if im a bit slow, im quite new to this!
can you explain it a little mor exact?
thanks
//david
SpufuZ
oh! i think the coin fell down. hehe.
so is this how it could be done?
Skreddy
Actually I was thinking something more like this...
SpufuZ
ok! i see! thanks!
But are the 220K resistors needed, and what are they there for? Stupid question maybe! =)
Btw, would 100k pots work fine?
Skreddy
Those are what make the phase-selector switch reverse the phase of the signal and maintain a 1:1 gain of the signal at the same time.
A 100k Blend pot would work, but might possibly be quieter in the middle and louder at either end.
Quote from: SpufuZ on March 17, 2006, 02:01:02 PM
ok! i see! thanks!
SpufuZ
ok i see! thanks for all help this far!
SpufuZ
OK i think i need some help here.
Ive soldered the IC1A&B now and tried it to see if it worked. And what i get is a "bluddery" small distorted and quick fainting sound.
I kinda have to strike the strings hard to get any sound at all. Get it?
I wired lug 1 on the IC to output as on the schematic above, and lug 7 nowhere since i just wanted to check if this worked.
No can this be done really? Or must the whole circuit be soldered for it to work?
I really cant find out whats wrong?
Anyone who can help me out with this?
Any ideas!
Skreddy
SpufuZ
yes i did!
strangely i got it to work yesterday but the tone was a bit harsh and a little distorted!
So maybe something is soldered bad? though ive been very careful when soldering!!
SpufuZ
to give a little more feedback, i discovered that i get almoast no sound, you know the "bluddery" tone i explained with a 9V Battery.
BUT, with the DC walltransformer (not regulatet so maybe a few more Volts than 9) i get more sound, and distorded tone!
What can this be!??!?!
