"Splitter-blend" question! HELP NEEDED! =)
Started by SpufuZ, March 16, 2006, 11:00:55 AM
Skreddy
Did you wire lug 7 to lug 6?
Wire lug 5 to input?  (or, instead of connecting to input, at least wire lug 5 to ground to silence IC1A during testing?)
Lug 8 to +9v?  Lug 4 to ground?
Did you create the voltage splitter for vref as pictured?
SpufuZ
ok! mystery solved!
I noticed that ive accidently put a 33k and a 330k!! resistor instead of two 33k in the IC "power supply".
So the problems solved, and it sound really nice! no distiortion, only a little hearable add on treble but i should try another input cap right?
what do you suggest?
i builded a transistor buffer last week and had a 100nF cap at the input, and a 10uF at out, and it didnĀ“t colour the tone at all!!!
gonna try that!
//dave
bancika
can this circuit be used inside tube amp as simple FX loop?
