AC-2 Part list
Started by bond, March 24, 2006, 12:48:02 AM
bond
anyone got one floating around?
bond
on the actual schematic/layout, R goes to 55 and C goes to 35  :icon_eek: i'm guessing cause part of the switching circuit was removed
anyways i've come up with
Resistors
10k   7
47k   4
100k   1
220   1
6.8k   3
2.7k   1
5.6k   2
3.3k   1
2.2k   1
680   1
68k   1
1.5k   1
27k   1
22k   1
39k   1
15k   1
180k   1
82k   2
39k   1
120k   2
150k   1
8.2k   1
12k   1
1m   1
5.1k   1
100   1
Transistors
2N7000   1
bc546   1
Pots
50k   1
10k   3
IC
tl074   2
Capacitors
0.047uf   3
0.018uf   2
0.056uf   2
0.0022uf   3
1uf   4
0.0047uf   4
0.1uf   2
0.0033uf   1
0.015uf   1
0.0039uf   1
0.01uf   1
820pf   2
200pf   1
68pf   1
22uf 15v   1
100uf 15v   1
10uf 15v   1
Diodes
9.1v zener   1
addicted2noise
hi i´m trying to do this project..this part list is ok??what type of capacitors did u use?did u succesfully build?
best regards
Gilles C
#3
Are you talking about this one (the original)?
http://pages.infinit.net/cbriere/userfiles/BossAC2.gif
Or this one?
http://pages.infinit.net/cbriere/userfiles/myac2.pdf
I took a quick look and saw a C37, so I don't know if you're taking about the same schematic/layout.
http://aronnelson.com/gallery/NaBos-Layouts/AC_2_Parts?full=1
Gilles
addicted2noise
i´m talking about the second one..the original schematic,there´s no layout or pcb around here...or it´s there anywhere??I don´t understand what happens with c38 ,just i don´t understand u..so on thankx anyway
cbriere
C38 is electrolytic , 100uF /25V, with the + side up.
it is used to filter the 9VDC supply.
have you checked Nabo's layout?, it is known to be ok,
cb
RaceDriver205
You should build the DIY version.
http://pages.infinit.net/cbriere/_sgt/f10000.htm
Has a Layout and a PCB
When you build it though, I would recommend you leave out the "Mid" Pot. The added mid control was not a part of the original, and I feel it alters the realism of the acoustic simulation.
