3pdt on PCB in expresspcb
Started by robkeeler, March 24, 2006, 09:32:07 AM
robkeeler
I was gonna make a 3pdt switch componant in expresspcb, but I found it can only do round holes.  Any suggestions on how I would get around this?
LyleCaldwell
What 3PDT switch are you looking at using?  Each one has a different pin layout.
What does this button do?
psionicaudio.com
shanter
measure the widest portion of each solder lug and add a tiny bit for clearance. but make sure u use that measurement for the inner diameter of the pad. Then just add a hefty amount of solder and u get a nice snug fit.
MartyB
I did it in Express PCB by putting the image in MS paint and creating the holes.  Alittle cumbersome but it works well for me.  In fact, all of my layouts I've posted were processed in MS paint eventually before posting.
Here's an example of the 3PDT-on-pcb:
http://aronnelson.com/gallery/MartyBs/r3pcblyt
robkeeler
So, just use the round hole but make sure the diameter is big enough for the rectangular pins?  I'm speaking about the regular old blue 3pdt.  Any other hints?
Peter Snowberg
Quote from: robkeeler on March 24, 2006, 11:16:00 AM
That's it. :icon_smile:
Eschew paradigm obfuscation
O
Quote from: MartyB on March 24, 2006, 10:49:04 AM
It seems that this gallery is no longer available. Did someone manage to make a copy of the 3PDT-on-pcb file? Thanks!
LyleCaldwell
Just measure from lug to lug in each direction, and make the holes with a diameter slightly larger than the width of the lugs.
psionicaudio.com
