Identifying a cap
Started by 1wahfreak, March 24, 2006, 09:31:26 PM
1wahfreak
Can anyone ID this cap. I've seen it in some "higher end" amps and pedals, but the funny thing is I bought it a RS (for $1.29!!) Iknow Rs carries some Alpha stuff and i've done some looking at Mouser but I have not seen anything.
PS click on the image for a larger view
rockgardenlove
A .1k cap?
Wtf?  No clue???
Weird.
TELEFUNKON
#2
metalfilm 100n
K=?
edit: Metallized Polyester Film
pyrop
#3
I think the "k" is to do with the voltage. "j" is usually more common caps we use around here.
edit: may also be the tolerance
pyrop ;D
Dai H.
probably metallized polyester, and K = 10% tol., so .1, 10% tol. 'J' would be 5%, 'F' was 1%(IIRC).
1wahfreak
Does anybody know if these can be bought at Mouser or somewhere else. I can't believe that well known amp makers and pedal builders are buying them from RS at 1.29 ea.
Dai H.
probably something like this:
http://www.mouser.com/catalog/625/634.pdf
modern parts like that should be ultra cheap in quantity.
