Muff Fuzz drive!
Started by tiges_ tendres, March 27, 2006, 12:34:53 PM
tiges_ tendres
So I think I'm becoming a tweaker!!
I perfed this up from the schematic that's floating around.  I socketed the input, output caps and the diodes.  The other major change was that I made my own layout to accomodated an SIP-8 4558 chip that I got in my removed parts selection from analog man mike (thank you!)
I put two 1n34a diodes in, and all the fuzz was gone!  I was left with an awesome over drive sound!
I didnt really like the stock sound of this one, a bit too bassy, the fuzz wasn't really doing it for me.  I tried LEDS, all kinds of diodes, but the combination of the 2 germaniums blew me away.
I cant decide on what caps to put in the circuit, I think I'm going to put two rotary switches in, hopefully, with 7 caps on input and 7 caps on output.  When you pull one of the diodes, the fuzz comes back, so I think I will add a 'lift' switch also to lift the one diode out of the circuit.
If my math is correct, that will give me 98 different combinations!  more than any man needs.
*edit*  I should point out this is the opamp version, not the transistor version.
Try a little tenderness.
bass_econo
Any chance you can make some sound clips?  I was just looking at the opamp muff today.  I'm very interested.
tiges_ tendres
Quote from: bass_econo on March 27, 2006, 02:07:35 PM
I'll see if I can have a crack at it.  Ive got an opamp muff fuzz and and an opamp big muff, I'll see what I can do.
Briggs
Quote from: tiges_ tendres on March 27, 2006, 12:34:53 PM
I really like the idea of rotary switches... where do you get some of those, or do you have to make them?
Briggs
tiges_ tendres
Quote from: Briggs on March 27, 2006, 03:43:15 PM
Briggs
http://www.smallbearelec.com/Search.bok?category=Switches&searchpath=421d832e10a3bbe4f59a4&start=25&total=31
most places have rotary switches of some kind or another.
Briggs
#5
sorry dbl post :-\
Briggs
Quote from: tiges_ tendres on March 27, 2006, 07:33:02 PM
Briggs
thanks!!! I needed to know this! ;)
bass_econo
I got side tracked and built one of these last night... unfortunately it does not work.  Only lots of loud hum...  I was too tired to really get into it late last night but I did take a quick look at it this morning.  It seemed that the circuit was correct and I think it's wired right.  I'll have to take a look later tonight.
Any ideas?
WGTP
Stomping Out Sparks & Flames
WGTP
tiges_ tendres
sorry, I cant figure out my sound card, so no sound samples.  I could maybe put it on cassette at a push!:)
and thankyou wgtp for those links!
bass_econo
Oh well, thanks for trying.  I built it last night but it has some problems.  I'm going to look at it again when I get home.  I hope I can get it going.  I'm going to build the Mockman too.  I love all of these opamp distortions.
If I get mine running tonight I will make some soundclips.
