Help with my second build - LITTLE GEM!
Started by Korwedge, March 30, 2006, 06:31:30 PM
bancika
Try with GUITAR speaker, it made much difference with my little gem mk2
Dr Ron
Have you put in the gain pot and turned down the gain?
There are only 2 places to generate distortion: the op amp or the speaker.
Turning down the guitar volume or using the gain pot will lower the op amp gain.
On the other hand, I recall reading that this op amp wasn't considered to be that good for audio.
Perhaps they were referring to the distortion sound you are hearing.
I'm getting a significant buzz from my little gem at all times,
until I unplug the guitar chord from the amp, then it's gone.
Any suggestions?
Joecool85
There will be no difference between having a gain pot in and set to no gain, and not connecting pins 1 and 8 at all.
Life is what you make it.
https://www.ssguitar.com
B Tremblay
Quote from: Joecool85 on April 08, 2006, 10:01:59 PM
Technically, with a 5k Gain pot at its minimum, there will still be slight increase in gain when compared to leaving pins 1 and 8 open.  In that case, the 5k pot is in parallel with an internal 1.35K resistor for a total resistance of 1.06K.  Whether that difference is audible is another matter entirely.   :icon_smile:
B Tremblay
runoffgroove.com
Joecool85
OK, so, there may be a little difference, in the WRONG direction, since he wanted it clean.
