digitech <bad monkey> is analog pedal
Started by wordstep, March 31, 2006, 12:34:10 AM
wordstep
maybe sb. know,maybe others not
<bad monkey>  use smt(surface mount technology) parts. double side pcb
there are 3   JRC4580  IC inside  and one 8 foot IC  close to the switch,i belive is
the bypass switch  IC
[ 14007U         ]
[ ON  PDW534  ]      the "ON"  IN A ROUND
and in the booklet of digitech , the distortion series  ( 5 pedals) all with "ANALOG"
<bad monkey>    mark   analog tube overdrive.
so these 5 are all analog.
it made in  china,the pots & input/output jacks are mounted directly on the pcb.
but the pots got sth cover to protect the wine into the box,
and the jacks mounts on the box too(double mount)
i like it ,and i think it can last longer than the digitech X-series( base on sth happen in line6 DL4)
just sth. input ,hope worth it.
hershey
no one ever
post in your original language! someone is bound to understand you.
(chk chk chk)
