GGG 6 band EQ
Started by andy123, April 05, 2006, 11:13:24 PM
andy123
Hi all,
Just wondering if anyone knows how much cut/boost the ggg 6 band EQ has?
Cheers
Andy
Dean Hazelwanter
I'll try to remember to dig out the original article tonight and check.
andy123
Cheers Dean.... Will keep an eye out.
Andy
Dean Hazelwanter
Ok, each band/frequency is specc'd at +/- 13dB.
andy123
Thanks Dean,
Sorry if this seems a bit obvious ........
but if I wanted to make a 10 band  version (like the MXR 10 band one) would I just add more op amps to the end of the chain with the corresponding Ca and Cb values?
Andy
343 Salty Beans
I haven't checked the schematic...
but you'll most definitely need more current, it'll sap a battery quicker. More voltage, I'm not sure.
Dean Hazelwanter
No problem Andy! :)
Yes, you're correct. Just add more of the gyrator circuits, the part that is duplicated for each band. That is what the original circuit was - 10 band. While it will draw a little more current, it won't be lots - all you're adding for active stuff is another TL074.
andy123
Cheers Dean and Salty beans.
Another project to add to the list...    :)
Andy
343 Salty Beans
when I say you need more current...just try not to use a battery (solely). Use a DC jack instead, and a decent wall wart, to get enough current, cuz more op-amps and whatnot will suck the charge out of your battery pretty fast.
Happy building, bro
