Keeley Boss DS-1 Ultra improvements
Started by Nuts, April 06, 2006, 05:29:22 PM
Nuts
Today I got a Keeley Boss DS-1 Ultra, and I can't be more disappointed  :(
Before I bought it I was reading amazing reviews on that pedal (rate of 9.5 from 90 people) claiming for a thick, full, Marshall tube sound
After a long messing with the setting, I could't get a decent sound out of it, only a thin, metalic sound.
Does anyone know what I'm talking about ? or/and can tell me how to improve that pedal?
thanks.
Alex C
What guitar/amp/pickups/speakers are you using?  All of these can make a huge difference in the sound.
Also, have you heard the DS-1 before the mod?  Maybe all those reviewers were hearing a thick, full, Marshall tube sound compared to the fizzy harshness of the un-modded DS-1.
Finally, did you buy it direct from Keeley or from Ebay or another source (if other source, are you certain of its authenticity- is it really a "Keeley")?
JimRayden
but first of all - make sure you plug into a guitar amp. No guitar pedal sounds good when plugged into hi-fi amplification or PC soundcard, even when they're advertised as full, thick, marshall sounding. They'll sound, as you said, extremely fizzy.
Jimbo
Ed G.
What kind of amp you using it on? I can't get even a modded DS-1 to sound any good on my Fender Super Reverb. I had one, modded it to Keeley specs, and while it was an improvement, it still didn't work for me.
jxoco
I have a DS1 modified to the 'Keeley specs' and it does sound good. With the tone at the top it gets screechy and so I don't use it that way.
I thought that the ULTRA was more of a mod to boost the output, make it act more like a Treble Booster
jxoco
Satch12879
Smells like a miswire; mine was tasty AND quiet right off the bench.
Passive sucks.
Progressive Sound, Ltd.
progressivesoundltd@yahoo.com
delbowski
i think that the ultra mod puts another LED in the clipping section.  i find LEDs to be kinda harsh, so maybe that could be the reason you're not experiencing those marshall tube sounds you're looking for?  just my two cents...
del
Nuts
I was checking it with Les Paul Studio and a Fender stage 185 amp, and the amp got a better distortion built it.
I have also 100 W tube Marshall, so I want to get my fender amp sounds close the marshll.
the pedal got the Keely stickers, with the led in "O" and the toggle switch, I also check inside an saw changes, so I guess it's a Keeley.
JimRayden
So you want a solid state Fender to sound close to a tube Marshall, huh?
Here's a spoiler. Santa doesn't exist!
(Sorry I couldn't resist. ;D)
Okay, jokes aside, Fender amps, especially the SS ones, do sound harsh. One thing you can do is replace the speaker for a Greenback or similiar. That should help you closer to Marsha but it'll still remain what it was designed as.
Then you could try the BSIAB2.
Jimbo
Nuts
#10
I have to say that today I'm little more satisfied with it, I just needed to mess the pedal more, but I'll still glad to hear any suggestions from you.
gulliver
Really, this pedal's specialty is getting very high-gain out of an already high-gain amp. Try it to get a little extra oomph out of your Marshall, you may love it. Start with the distortion and treble on 10:00 and adjust each to taste.
wampcat1
Quote from: jxoco on April 06, 2006, 06:17:05 PM
there are soundclips at this site to compare to your's
http://www.indyguitarist.com/mods.htm
Those soundclips are of my mods, not of keeley's though. Keeley's pedals sound different than mine.
Keeley should have clips up as well though - look through www.rkfx.com
bw
George Giblet
Those things have always sounded cheap and buzzy to me too.
However I found this recently.
http://p221.ezboard.com/fdigitechrp2000usersforumfrm4.showMessage?topicID=14.topic
Scroll down half way 'til you get to the poster "Inaweofschon".  The post has text "Hearing a Neal Schon challenge made me remember"
I was willing to give the DS-1 a shot again.  I think turning the tone all the way to 0 might be going a bit far, but many people have said to keep the before the 12'O Clock position and to have the amp already distorting.
Alex C
I think Joe Satriani might not use the DS-1 anymore now that he has his signature amp, but when he was using it for his main sound, it was more like a booster.  Vai does the same as well, using a distorted amp and using the DS-1 (I believe his is ultra-modded by Keeley) with a low distortion setting to push the amp harder (he uses a Tubescreamer in the same way, for a different tone, if you were wondering).
So when you hear that "the pros use the modded DS-1 to get their thick, warm tube sound," keep in mind that they are using it to boost a quality tube amp, and for the most part, not for its inherent distortion sound.
