help ! need orientation of four 1uf caps in boss cs-3
Started by bobster, April 28, 2006, 08:15:02 AM
bobster
hi folks-
i was modding / adding many new parts to my cs-3 and ended up creating a fault . i changed out the four 1 uf caps with non polar fim caps at  0.47 uf to see if that would help but it didn't. i have now fixed the pedal as i had burnt some traces so i put in some small jumper wires which cured that . i now want to put in tantalum 1uf caps in the positions where the film caps now are to help reduce noise. the trouble is , i dont have a schematic [ cant find one on google ] and dont know which direction / way to solder in the tants to ensure correct polarity !
if anyone could maybe post a pic of the circuit board with the 1uf cap orientation labelled id be most grateful
many thanks - bob
twabelljr
    Ok. Looking at the component side of the board with the wires at the top, this is the 4 1uF caps orientation:
C4 ---   + side up
C6 ---   + side up
C14 ---   + side right
C17 ---   + side down
Good luck!
Shine On !!!
