Current draw from opamp output
Started by markusw, April 28, 2006, 02:51:57 PM
markusw
Stupid Q:
which parameter do you check in the data sheets do see how much current you can draw from an opamp, e.g. to power a LED in an envelope follower???
Thanks for your answers in advance!
Markus
Sir H C
Should have specifications for current sinking and sourcing.  Sourcing would be current out, sinking would be current in.
Processaurus
The LM358 (dual) and LM324 (quad) are good for control circuitry like LFOs and driving an LED in effects with a single supply.  They're cheap and power efficient too.  For current sourcing it looks like it can put out 20mA minimum, 40mA typically.
http://cache.national.com/ds/LM/LM158.pdf
markusw
Thanks  for the clarification!
In case of the TI NE5532 http://www-s.ti.com/sc/ds/ne5532.pdf it would be "Output short-circuit current" ??
Markus
Sir H C
That gives you the limit that it can source/sink.  Also it tells you that it can drive a 600 ohm load.
