DIY Layout Creator - software for easy drawing PCB, vero and perfboard layouts
Started by bancika, May 01, 2006, 08:00:21 PM
great program...i would like to still have the parts list display option like the older version. though!...
instead of having a seperate bom txt file.....thats my 2p worth!. :icon_mrgreen:
bancika
clamup1
hey is there a usable link to the old version of diyc. im using the beta version and its anoying but usable. the link posted farther back dosent work.
Quote from: clamup1 on September 06, 2010, 04:56:59 PM
bancika above this..!..diy fever/software....should be ok...
Perrow
anoying but usable.
Have you unchecked the "sticky points" option? (in the "Settings" menu). That's about the only annoying feature in that program.
clamup1
thats the beta version. i have that one. i like the sticky points for some thing. sometimes where i want to put stuff isnt a point on the grid so i have to turn it off.
i noticed that there isnt a manual for this program. i was wondering if there is code for changing the width of traces and the size of pads before getting started on a layout so one dosent have to do it every time they put a new trace or pad on a layout
bancika
you can hack xml files in the library, should be straight forward as they contain default values.
bassmannate
Any one else have issues in Linux with the java version? It looks like the stuff is there in the library because if I click and drag from the library window, stuff shows up in the main window but you can't actually see anything in the library window. Kinda working in the dark.
GodSaveMetal
dear bancyka it's a actualisation of the collection of boards made with this excellent program??? I have some circuits to contribute for it!!!! where to post o how to donate this??
bancika
you can send circuits or paypal donations to bancika at gmail
I'll include them in the zip and re-post.
stcook111
It's coming along nicely. Noticed that some components don't rotate properly. Specifically the tube schematic symbols. A flip (left to right) and invert (top to bottom) commands would be a nice feature.
mr_deadmaxxx
PCB Wizard Pro Unlimited works for me..
you can design your pcb etch manually or you can just let the proram do the design for you.
bancika
The latest alpha can be found here http://code.google.com/p/diy-layout-creator/downloads/list
I'll update it approx once per week with new features and fixes.
Cheers
Johnfreeth
This one is much quicker than previous version-- Can't wait for the updates
Thanks for all your hard work
GodSaveMetal
Goodness!!!! I already now prove this new version and is great It's very fast and have the *.pdf converter!!!!! great; I'm waiting for the extension of the product more elements and compatibility with the old version!!! it's great congratulation for all!!!!!!
bancika
glad you like it guys. I'll put the new alpha in few days, with a few improvements, bug fixes and new components. Stay tuned  :icon_wink:
You can use http://code.google.com/p/diy-layout-creator/issues/list to see bigger things that are in the pipeline, or to suggest a feature or report bugs.
Cheers
bancika
Hey all,
I put the new version up, same old http://code.google.com/p/diy-layout-creator/downloads/list
Changes include:
* fancy component creation system, d&d from the toolbox is still not supported, but it's still much better.
* bunch of bugs fixed (most of bugs reported by Paul F and a few I found myself)
* a couple of components added
* added "Lock layer" functionality
* added ability to unstuck components by holding ctrl
Cheers,
Bane
GodSaveMetal
Quote from: bancika on January 23, 2011, 01:54:39 PM
Hey all,
Changes include:
Cheers,
Bane
Yeah great but there's no tranis, FET, LED others; please complete that!!!! thanks, your making a good job!!!!
bancika
rich component set is not my first priority, maybe not even second at this point.
I'm trying to iron out usability problems and make a good platform that can be extended better. If I have 100 components and I change something, I have to update all 100 of them. If I have 20 it's less work :)
cheers
