DIY Layout Creator - software for easy drawing PCB, vero and perfboard layouts
Started by bancika, May 01, 2006, 08:00:21 PM
Perrow
stirfoo
Thanks Perrow. I've rearranged it a bit after correcting the relay width (as ICs on the board). It should just have an empty strip at the top and bottom now.
Probably still need to proof-read it about 10 more times.
http://i.imgur.com/wWxj90L.png
And I just noticed I don't have cuts under some of the relays.  :icon_eek:
Perrow
Quote from: stirfoo on March 01, 2013, 06:22:21 PM
If you're anything like me, it'll need one more proof-reading after it's built (independent of how many times you've proof-read it before building it). I can have up to about five components before that rule works every time, with less components it's intermittent.
Perrow
Bancika, any estimate when you've fixed the "Copy throws error" bug? It's highly annoying for someone who copy/pastes a lot and can't open the file in the previous version :(
I know you work on this in bursts (is it a Burstbox program?) and I seem to remember you saying you had little time for this right now, but would really like this one fixed.
bancika
Perrow
bancika
Perrow
Perrow
bancika
Perrow
bancika
Perrow
QuoteSaw that you fixed it, but no. Still get "Could not set component type slot" error when I try to paste.
Quotehow about now?
It's fixed, thanks Bancika!
bancika
Perrow
fuzzymuff
Noob here.  First time using the DIYLC.  Did I make this vero layout of the sili fuzz correctly?
fuzzymuff
