DIY Layout Creator - software for easy drawing PCB, vero and perfboard layouts
Started by bancika, May 01, 2006, 08:00:21 PM
Gilles C
I tried to desactivate any spyware and antivirus programs I use on my PC and it changed nothing on my PC.
Maybe something was still there, maybe not. I have a well protected PC...
So it's not working for me. And I never had any alarm as you did. So I'm not sure if this is the reason. One thing for sure, you found something.
Gilles
beer
did you start DIY-LC after you turned it off ?
otherwise it dos'nt work.
bancika
Quote from: beer on September 24, 2006, 03:26:21 PM
i don't think you can put it on a "White list" programwise , it's a manualy thing the user has to do , i think.
I didn't mean to put it programaticaly on white list, but to advise users to do it manually. I don't think that simple fooling with new proc will do anything...I mean, the same code will be written in exe somewhere and damn thing will find it  :icon_twisted: :icon_lol:
Gilles C
Quote from: beer on September 24, 2006, 03:43:30 PM
Yes, and I tried a last time after shutting off what I could. Still didn't work.
Sorry.
bancika
are you sure that AV didn't stay in background. If it has "Disable" option use it instead of shutting it down. Maybe it's DLLs can be active after you turn it down
Gilles C
Nah. Doesn't change a thing for me.
It is set-up to warn me of detections anyway, and there's nothing in the logs.
beer
Well , i did'nt get any messages either , i just switches the AV off and then it worked.
and nothing in the logs either.
So it was kind of a "lucky strike"  :icon_biggrin:
bancika
it's very hard to develop software that ill work everywhere these days. Too many variables, different components, AV and Firewall software standing on your way... :icon_mad:
d95err
Antivirus problem fixed!
As I said, I submitted the exe file to Sophos, and today I got the following answer:
Hi Erik
please accept my apologies for the delay in getting back to you. The file DIYLayout.exe that you sent to us for analysis was producing a false-positive report. This should now have been corrected and you should ensure that you have all the latest IDE files applied. Please do not hesitate to contact me if I can be of any further assistance.
Regards
Martin James Elliott
Technical Support Specialist, Sophos
I checked it by reinstalling the DIY Layout creator, and it works without problems!
bancika
beer
Hi again ...
Just a thought , bancika , did you think about converting to an other format than XML , to get aruond the AV ?
i use inifiles all the time and as long as they don't get to big (1-200 items) the are quite fast.
and they are easy to work with.
and another , how about making a "user library" where it is possible to make your own components.
maybe make some kind of "fixed" drawing with the leads stretchable.
or just "drop" it and jumper the rest.
Again , i'm just throwing ideas/thoughts out in the open.
Sorry if this has already been discussed , i did'nt read the WHOLE Thread.
bancika
I wouldn't use anything else for simple reason: XMLDocument provides very easy access to nodes without need for parsing/writing to XML structure. If I used ini files I'd have to make new structure in memory and write separate Load/Save routines. XMLDoc has SaveToFile an LoadFromFile...very handy :)
beer
well , i'm not familiar with "XMLDocument" , so i would'nt know whats best.
Which version of Delphi are you running ?
bancika
Delphi 7 Professional. Believe me, XMLDoc makes things much easier...and those AV companies should really develop little smarter detection engines  :icon_smile:
bancika
I just uploaded new version. New stuff to try:
  • Three different sizes for electrolytes. To mantain compatibility with previous versions older electrolytes are considered Medium sized (just like they were before)
  • Changing colors to traces and solder pads. Now PCB layouts can look much better and more colorful :)
Cheers
skiraly017
Quote from: bancika on September 26, 2006, 01:45:08 PM
Cheers
Love the new stuff. Any chance we could get icons for axial electrolytics? I don't know about anyone else but I do use them on some projects. Thanks!
RLBJR65
Sweet :icon_exclaim:
I always liked the color traces on TonePad layouts. Makes it easier to do a layout. Also very helpfull when debugging.
Richard
Richard Boop
stm
Nice additions. The variable-sized electros are great.
There's a small bug in one of the pot shapes.  When you select the pots with the pads "almost in line" four pads are created instead of three.  Two pads are at the same location, thus you actually see three of them.  I verified the four pads are also in the saved file.  The other pot patterns with the pads more spread apart seem to be fine.
bancika
markm
Also,
Seems to be a problem printing PNP now that I just did the update.  ???
