logic gates
Started by ingrowing_whale, May 04, 2006, 10:50:01 AM
ingrowing_whale
Hello,
I'm doing a circuit using cmos 4000series gates. The circuit doesnt seem to work because when I turn the thing on the Q and Q\ outputs are both at high level. Is this because I'm trying to use 4.5V instead of 5V? Thanks.
The circuit works fine on simulation with ISIS.
ingrowing_whale
actually,
every input and output that are linked to the circuit have got a high output.
gez
Quote from: ingrowing_whale on May 04, 2006, 10:50:01 AM
The 4.5V wouldn't matter.  I take it you're using a flip flop.  With the 4013, in 'direct' mode, if both set and reset are high then both Q and Q/ will go high for as long as both inputs remain so.  Is this your problem (these outputs might be holding everything else high)?
gez
PS  Check you've got a ground connection for all the chips.
ingrowing_whale
nope the reset and set pins aren't linked to anything. It's a 4027 flip flop
ingrowing_whale
could it be the fact that the J and K inputs are at high level? It worked on the simulation but I supose that might be a problem, because J=1 and K=1 isnt a combination in the datasheet
Processaurus
Quote from: ingrowing_whale on May 04, 2006, 06:04:38 PM
I'm not sure about everything going on, but all the inputs (including set and reset) need to be tied to a logic level. looking at the data sheet
http://pdf1.alldatasheet.com/datasheet-pdf/view/26863/TI/CD4027.html
it says the set and reset is triggered by a high signal, so ground each of those pins if you aren't using them.
ingrowing_whale
ok that's gonna be a hard one but I'll try. Oh yeah the vss input is linked to earth. Is this right?
ingrowing_whale
I also have another problem :
My RS gate made out of NOR gates doesnt work either. I have the right ouput levels before pressing on my switch, but when I let go of my switch the outputs just go back to normal. There is no latching action.
gez
Quote from: ingrowing_whale on May 05, 2006, 04:22:57 AM
The set & reset need to be tied to a logic level.  Whether it's high or low will depend on what you wish the FF to do (check data sheet/on-line tutorials/CMOS Cookbook).  If you're clocking the thing, tie them both to ground.  This isn't an option.
Yes Vss pins are tied to ground.
gez
Quote from: ingrowing_whale on May 04, 2006, 06:34:25 PM
In clocked mode the J & K inputs decide what the FF does.  What do you want it to do?
PS  If you can afford it, CMOS Cookbook by Don Lancaster is a must...has all this info in nice handy format.
ingrowing_whale
flippin heck I can't believe this one :
I mesure the voltage at the 2 in pins of my AND gate : 1=0.35V 2=3.5V and the ouput is 3.5V. This shouldn't happend should it?
gez
It would help if you posted a schematic, or at least outline what you've done so that 'normal' can be defined.
ingrowing_whale
#13
Ok here's the schematic :
http://daniel.hayter.free.fr/finaldesign.BMP
ok this is how it works : you select which way the motor will turn with the JK flip flop. You then activate the motor with the RS flip flop (the NOR gates). The motor then turns until it has turned 5 times (12 pulsations from the clock which is physically attached to the motor so don't worry about the clock). Then it stops. However if the motor turns too far, there is a security detector which is the switch SW1. Once this switch opens, the motor stops, the system is reinitialised and the JK switch toggles and you can't rechange the direction untill the SW1 has closed again (when  the motor has turned the other way). Voila!
oh and I linked the set and reset pins to the ground and that works now so that's not an issue anymore :
Here are the issues :
When I press on the push button to activate the RS flip flop there is no latched action and the output just goes back to 0 after having let go of the button.
The U3:B output is high even though it shouldn't be meaning that I can't change the direction with the JK flip flop.
ingrowing_whale
I think i've found something that could help :
The output 10 of the AND gate is low (0.001V) however after the diode 12 the tension is 0.5-0.6V which could be causing the problem of the high output in the next AND gate. Does anyone know why there is 0.5V at the output of the diode?
gez
If I have some time this afternoon I'll scan thru the schemo.  Thanks for posting it (saves stabbing around in the dark).
gez
Haven't had time to go thru whole schematic yet, but the thing that first strikes me is you're loading the outputs of the flip flops heavily.
You haven't specified what the supply is on the schematic, but I think you said it was under 5V (are you using a 5V regulator and if so, what's it's max current rating?).  Going by that figure, and having checked a few data sheets for the 4027, I don't think they're going to be able to cope with those sort of loads.  Does the base current of the relay drivers have to be so high?  Would it be better to use MOSFETs?  Would it be possible to use more efficient LEDs?
Don't know if you have other problems yet as I haven't gone thru the schematic in any detail.  Will do so when I have another spare moment.
gez
Quote from: ingrowing_whale on May 05, 2006, 05:30:41 AM
Try removing the load.  Does it latch now?
ingrowing_whale
what do you mean by load?
ingrowing_whale
do you mean I should put a smaller resistance after the push button?
