EA Trem---questions
Started by rockgardenlove, May 11, 2006, 02:14:21 AM
rockgardenlove
So I breadboarded an EA Trem because I didn't have quite the right parts, and I wanted to see if it would still work.
It didn't work, and I'm fairly sure its breadboarded correctly...these are the parts I replaced:
180ohm-150 ohm
1.2k-1.3k
120k-130k
1uf-1uf(electrolytic polarized)
2.2m-2.7m
15k-12k
As you can see, I made quite a few part substitutions.  Just for reference, here's the schmatic:
Are my parts at fault?  I just want to know before I go and order a bunch more components.
I think I may have conceivably gotten the pinouts wrong though.  For the J201 JFETthe source connects to the ground...is that right?  I tried flipping the J201 both ways though, and it didn't work.  How does the mosfet go in there?  I'm a bit confused as I havn't used a mosfet circuit before...how does the symbol denote how you situate it in the circuit?  I tried searching around, but couldn't find anything.
pyrop
With the flat side looking at you
left pin - drain - goes to 22uF cap
center pin - source - goes to ground
right pin - gate - goes to wiper on the depth pot
You should get still get sound without the J201 in place I think.
For the 1uF caps I have seen a schematic them polarized. The horizontal ones had the - on the right and the vertical one had the - on the bottom as viewed on the schematic.
Hope you get that!
pyrop ;D
rockgardenlove
Alright, great man.  Thanks.
Mind giving me the same info for the BS170?  :)
I got some sound...it just didn't trembobulate at all.  Parts issue, or my breadboard issue?  What do you think?
(I'm leaning breadboard...mines too small so I have trouble cramming it all in.)
brett
Hi
BS170 is DGS with the flat side towards you. (2N7000 is SGD just to be confusing).
Does the LED pulse?  I'm guessing not.  Probably because it's best not to use polarised caps in such a circuit.  Especially for the one that bridges the other two, as it has no polarising voltage on it.  Try MKTs or greencaps.
Brett Robinson
B Tremblay
My guess is that the transistor orientation is wrong in at least one section.  Those parts substitutions are probably minor enough that they wouldn't affect the circuit's operation.
Regarding the usage of polarized 1uF caps, I've had no problem with them in my two builds of this circuit.
B Tremblay
runoffgroove.com
rockgardenlove
Ok, cool.  I'll try to find that PCB to try it.
markm
Quote from: B Tremblay on May 11, 2006, 08:48:45 AM
Same here.
No problems.
brett
QuoteRegarding the usage of polarized 1uF caps, I've had no problem with them in my two builds of this circuit.
There goes another theory!  Live and learn.  Hehehe  :icon_wink:
Brett Robinson
rockgardenlove
So on Q1 what does the drain, gate, and source connect to?  I don't get the icon for Q1...thanks!
pyrop
Quote from: rockgardenlove on May 16, 2006, 02:24:04 AM
Drain to the 4K7 resistor
Gate to input
Source to 180R resistor
pyrop ;D
rockgardenlove
But then the trimmer isn't connected to the drain, and so you can't tweak the drain voltage with the trimpot?
pyrop
#11
Quote from: rockgardenlove on May 16, 2006, 03:04:36 AM
That is right the drain voltage is tweaked through the trimpot which is connected to both the drain (via the 4K7), the gate (via the 1M) & to ground.
Think "Feedback" loop/resistor
pyrop ;D
rockgardenlove
Well uh, its not changing anything at all.
pyrop
Quote from: rockgardenlove on May 16, 2006, 03:46:58 AM
Do you have any voltage? & you are measuring the drain? (pin connected to 4K7 resistor)
pyrop ;D
rockgardenlove
Yeah...uh.
I'm using a 50k trimmer atm...it should still fluctuate somewhat though.  Battery at 9.3 volts, drain is steady at 2 or so volts.
pyrop
Quote from: rockgardenlove on May 16, 2006, 04:37:48 AM
Yeah...uh.
Needs to be a 100k trimmer or at least run a resistor in series with the trimmer ie 9v+ - 50k trimmer - 47k or 51k or 56k resistor - ground
pyrop ;D
rockgardenlove
^Yeah, before that I tried using 33k fixed resistors before and after...
Its 2:37 AM and I'm multitasking.  That's the problem.  Tomorrow I'll wake up and find out I've made some incredibly obvious error :)
rockgardenlove
Ok, so I've gotten it to sound, no oscillation though.  The LED lights, but doesn't blink.
pyrop
Quote from: rockgardenlove on May 18, 2006, 09:51:47 PM
Double check the Q3 pinouts.
And from what Ive seen this is how you would place those polarized 1uF caps
pyrop ;D
rockgardenlove
Fixed, I got a bad trimpot somehow.
Thanks though!
