Anyone mod a T-Rex Mudhoney?
Started by somis9, May 16, 2006, 01:22:44 AM
somis9
I wanna put a DPDT switch in and make it true-bypass. Apparantly it uses FET switching and there are only two leads between the board and switch. Everything is mounted to the circuit board and I think if I can break the hard line from the input to the effect circuit input I can rig it up. Anyone ever work on this or any T-Rex pedal?
MartyMart
I have a "Dr Swamp" pedal, they are not "surface mount" components, so it would be possible
however without a properly traced out schematic, almost impossible !
It uses electronic switching, but is very high quality and does NOT suck tone IMHO, so unless
you have a real problem with it, I would leave it alone.
Do a search for "true bypass" it's interesting, not everyone's favorite system, including Pete Cornish
and Roger Mayer :D
Having at least a few "Buffered/electronicly switched" pedals in your rig is a GOOD thing !
Cheap versions, such as the dano's even sound fine, just the switch/jacks physically break too
easily ...
MM.
Sam
I never had any tone issues with the electronic swithing in my Mudhoney. Being the curious type I still opened it up but quickly came to the conclusion that any mods would indeed be very hard since they have installed the PCB in a way that nothing can be reached (or even seen). The bypass is really high quality - the only problem I've had with the lack of true-bypass is in taking advantage of the high-Z input on my SHO when it's placed after the Mudhoney. And Mudhoney seems to have problems being fed by the SHO booster.
Very nice pedal indeed. I use it for lower gain distortion since it's so dynamic and responds well to playing style while still retaining an aggressive tone.
"Where's the paper bag that holds the liquor?
Just in case I feel the need to puke." - Silver Jews
somis9
interesting marty, i will look into that.  i know, the Mud does an excellent job at bypassing, just figured i would investigate.
i will probably leave it alone, i would have to be cutting on the PCB to accomplish TB and it's a new $200 pedal so...
