Simplified DS-1 circuit
Started by akozols, May 24, 2006, 12:27:47 AM
akozols
  HI,
    I have a DS-1 that I did the Keeley mod to.  I wanted to get it back to stock, so that I could do one change at a time to see how it would sound.  Due to having a bad day, I have the pc board broken into 5 pieces and all the original components.  I glued it back together, but trying to repair all the traces with jumpers is getting out of control.
  I was thinking of pulling the parts and making a simplified version of the DS-1.  All I need is the signal path to make it to the output,  I don't need the switching or led ctl.
  I went to tech school over 20 years ago and have forgotten most of it.  I remember seeing somewhere, small sections of circuits and what they did.  Can you tell me where that link is?
  If you have any ideas to use the parts I have to make the signal only DS-1 please post it.
  If it's any incentive, I'll probably have the DS-1 case(SEM already installed) to give away when I'm done.
thanks,
Al
Guga Ramone
Here is a simplified version of the DS-1: www.tonepad.com (click on fx projects, and there you go!)
Hope it helps!
I doubt that you'd send that boss case to Brazil... But, if you want to, I'd really apreciate!
Good Luck, fella!
akozols
  I appreciate the link, and I would love to send you the case......but........I checked shipping, and it's $23.  OUCH.
thanks,
al
Guga Ramone
Don't worry, bro!
Just be sure to ship it to someone that will make a good use of it!
Cheers!
