PCB-Drawn with Bancikas PCB drawer! Does it look ok?
Started by rockgardenlove, May 24, 2006, 02:12:50 AM
rockgardenlove
So here's my first ever PCB...its basically the newbie boost, but on PCB.  Does it look ok?
Unbeliever
It's not clear to me what the +ve side of C1 should be connected to. The top of R3? Can you make the 'objects' more transparent so the tracks are more visible?
rockgardenlove
The program doesn't allow that...yet :)
The + side of C1 connects to the collector of Q1
The - side of C1 connects to R3 and the output.
rockgardenlove
bancika
Nice idea..the transparency. Thinking about way to do it  ??? :icon_rolleyes:
Alex C
What schematic are you using?  I'd like to compare it with the layout.
It looks nice.  Do you have a previous version, perhaps one that you made before placing the components?
rockgardenlove
The basic schem is in the tutorial forum :)
It's just a little booster I was going to after my spring reverb.
Unbeliever
Quote from: rockgardenlove on May 24, 2006, 10:43:34 AM
So, does it look alright guys?
From a visual / artistic sense, yes, but if it's not clear how the circuit should hook up then maybe it's not as useful as it could / should be? Maybe there could be an 'outline' mode where the parts are just outlines, no fills. I always end up printing out layouts on paper anyway (to refer to when building), so this mode would be most useful to me.
Looks like a neat application so far, though. Kudos.
JimRayden
Quote from: Unbeliever on May 24, 2006, 03:34:38 PM
It is extremely useful. You can't see the traces quite clearly in this render but the program has a PnP print feature that automatically only prints the traces. From that on it's quite simple to associate this layout to your PCB.
Jimbo
Unbeliever
Quote from: JimRayden on May 24, 2006, 03:44:12 PM
It's still not clear on-screen though is it? For me, at least, this would make slightly harder to do a 'layout' if there isn't a 'mode' where I can see the parts AND tracks clearly at the same time - hence my constructive criticism. I work from printouts that have parts and tracks on them, BTW.
Anyway, I'm sure the creator is capable of making any improvements, if he / she wishes to. :)
Mike
PS Excellent link for software developers  - http://www.codinghorror.com/blog/. If you're not reading this, you should be.
JimRayden
Bancika included the transparen-function already, check the 10-page thread about the prog.
Jimbo
rockgardenlove
^Read the post he made above....I don't think it is included.  And I dunno how to show the traces, there is no export PNP file.
JimRayden
Quote from: rockgardenlove on May 24, 2006, 06:42:54 PM
In the program's home thread, he states that he included it but there's no beta with this feature yet.
There's no export for the PNP but there's a semi-functioning PNP print feature. :)
Jimbo
rockgardenlove
Well, just say then, does this circuit work if I take out the electrolytic off the emitter of Q1, and put a pot varying the voltage going to the collector?
bancika
I didn't include PnP export yet, either I made mistake writing it in post, or you read it wrong :)
It will be very soon  :icon_cool:
rockgardenlove
So will that n00by circuit work with the electrolytic cap and pot removed off the Q1 emitter, and with a pot added to the collector current?
bancika
Try to render same project with new version, it will look much nicer.
JimRayden
Quote from: rockgardenlove on May 25, 2006, 04:21:52 AM
The pot is on the collector if you haven't noticed.  ;)
Jimbo
rockgardenlove
I'm trying to take out the 5k pot and replace it with a fixed value and then add a 10k pot on the collector...
That will work, right?
